Pilot bushing #120264
09/13/08 06:57 PM
09/13/08 06:57 PM
70duster340 Offline OP
How does one remove the pilot bushing from the rear of the crank? I take it it just doesn't slide out.
Re: removing the Pilot bushing [Re: 70duster340] #120265
09/13/08 07:05 PM
09/13/08 07:05 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
Some become loose enough during use to just slip out when the trans is removed. Yours, I'm sure will seem to be "welded" in.
They sell special slide-hammer attachments that can be used to grip the inner edge of the bronze bushing & then a few taps & usually out it comes.
You can also pack the crank hole with wheel bearing grease & using an old pilot shaft or sometimes a clutch alignment tool, insert the shaft into the bushing, smack it sharply with a BFH & out should come the pilot bearing...
Good luck & watch the grease!
Re: removing the Pilot bushing [Re: zooom] #120266
09/14/08 12:15 PM
09/14/08 12:15 PM
Hmmm....sounds kinda messy with grease shooting all over. You are correct that it seems welded in. I tried just reaching in with a finger and removing it, but it won't budge. Guess I need to look for the tool, huh? Is this tool just for Mopars, or do other makes utilize the bushing as well?
Besides that, I only have a plastic clutch alignment tool that came with the clutch. I don't think that will stand up too well to a BFH!!!
Re: removing the Pilot bushing [Re: zooom] #120267
09/14/08 12:24 PM
09/14/08 12:24 PM
I tried that once & all I got was a face full of grease.
Re: removing the Pilot bushing [Re: RapidRobert] #120268
09/14/08 12:28 PM
09/14/08 12:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
wrap a rag around the tool under your hand against the crank to catch the grease .
the bushing is held in with a press fit , meaning its OD is bigger that the hole in the crank , if you were able to just pull it out something would be DAMAGED , never mind what damage it would have been doing to itself or the crank the hole time it would have just been spinning freely inthe end of the crank ...
Re: removing the Pilot bushing [Re: JohnRR] #120269
09/14/08 04:12 PM
09/14/08 04:12 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've used the grease trick and it worked like a charm...
Re: removing the Pilot bushing [Re: screamindriver] #120270
09/14/08 04:47 PM
09/14/08 04:47 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
They make a cheap tool you can get at harbor freight that works like a charm...couldn't be easier
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
