Water neck gasket leaks - blown head gasket?
#1202008
03/23/12 05:04 PM
03/23/12 05:04 PM
Posts: 561 Oakland, CA
68Bullet
Oakland, CA
Hi,
I keep fixing a leaking water neck gasket on my polara. It has a stock, tired, non-rebuilt 383. The problem is the flange where the thermostat goes in. It always leaks. I've fixed it a few times, and even bought a replacement new water neck. I clean the surfaces, use very light application of gasket sealer, and new gasket. I've done this several times. Funny thing is, it leaks even when I first start the car and the engine is barely warm.
I had a thought today. If the head gasket were allowing cylinder pressure to leak into the coolant, the water neck is where the leak would be seen, as the thermostat is closed. I haven't seen any traces of water in the oil, but the car does run hot even with a new radiator. Could a small head gasket leak be my issue?
"Broke is temporary, cheap lasts forever"
Re: Water neck gasket leaks - blown head gasket?
[Re: 68Bullet]
#1202010
03/23/12 06:15 PM
03/23/12 06:15 PM
Posts: 31,050 Oregon
AndyF
Pull the water pump off and bolt on this tool. Then you add some air pressure (30 psi max) and you'll know right away if you have a leak somewhere.
Hughes Engines has the tool. Part number is AR282.
[Re: Andrewh]
#1202013
03/23/12 07:20 PM
03/23/12 07:20 PM
68Bullet
Oakland, CA
I'll check to see if it leaks with the rad cap off. The thing is, it only leaks while it's running, which means either the pressure from the water pump (which is new) or pressure from somewhere else is causing it to leak.
[Re: 68Bullet]
#1202017
03/23/12 08:44 PM
03/23/12 08:44 PM
AndyF
That's a good idea, can I do the same thing with one of those radiator cap pressure testor things?
Yes, but then you are testing a lot more parts. The radiator, heater hoses, water pump, radiator hoses, etc. All depends what you're trying to solve.
[Re: ahy]
#1202018
03/23/12 09:49 PM
03/23/12 09:49 PM
68Bullet
Oakland, CA
Ahhh, I think I found one error. I know not to overtighten valve covers. But I have been cranking down on the water neck to fix the leak, which seems to only make it worse. I think I'll try removing it, using non-hardedning, and lightly torquing it upon reapplication. We'l see if that's the magic touch
[Re: 68Bullet]
#1202019
03/23/12 10:34 PM
03/23/12 10:34 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Right to a point but not completely. Do not over tighten is right because of possible distortion. I would use a gasket with some non- hardening sealer on it then tighten down snug, tight enough to seal but not twist the bolt off tight. Remember there is pressure build up at this point where with valve covers there is not a pressure point.
[Re: 68Bullet]
#1202020
03/23/12 10:35 PM
03/23/12 10:35 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
The aluminum water necks (and chrome plated versions) are well known for leaks (cheap and mass produced = low quality). Take your aluminum neck and block sand the mating surface on a course grain sand paper. I have also done so on a flat, unpolished concrete surface, figure 8 pattern). You will quickly see how uneven the cast aluminum mating surface is. Once you have a 100% contact surface, you will have a good leak free seal with just a little bit of RTV and a new gasket.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
