Need help with dates and codes #1201120
03/21/12 10:56 PM
03/21/12 10:56 PM
In a van, down by the river
jmf340 Offline OP
jmf340  Offline OP
I have a 69 Dart and the only info I have is the VIN number. No build sheet or fender tag. I would like to put it back together as close to original as possible, but have no idea about date codes or ranges of dates on specific parts to make it a reasonable project. The VIN sequence number is 355587. So what date range should the carburetor, alternator, hoses, coil etc. be in? Also, were the rear end housings coded in any way and where would it be located? Any help would be great.
Got Mopar???
Re: Need help with dates and codes [Re: jmf340] #1201121
03/21/12 11:07 PM
03/21/12 11:07 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Scheduled production date is either 422 or 423.Is your Dart an LM23 or LS23 ?
"Long Live Mopars"
Re: Need help with dates and codes [Re: Furyman] #1201122
03/22/12 11:37 AM
03/22/12 11:37 AM
jmf340 Offline OP
jmf340  Offline OP
LM23....
Got Mopar???
Re: Need help with dates and codes [Re: jmf340] #1201123
03/22/12 01:21 PM
03/22/12 01:21 PM
LM23....
According to the information I have that is a 1969 Dart Swinger 340 If so the VIN # should read LM23P I own a 1969 Dart GTS 383 car, LS23H welcome to the club
Re: Need help with dates and codes [Re: Cab_Burge] #1201124
03/22/12 02:48 PM
03/22/12 02:48 PM
jmf340 Offline OP
jmf340  Offline OP
Yes, 69 340 Dart Swinger. I am searching for date codes on all of the parts on the car and I need some help in making sure they belong with the car.
Got Mopar???
Re: Need help with dates and codes [Re: jmf340] #1201125
03/23/12 07:34 PM
03/23/12 07:34 PM
jmf340 Offline OP
jmf340  Offline OP
Anyone else?
Got Mopar???
Re: Need help with dates and codes [Re: Cab_Burge] #1201126
03/24/12 10:11 AM
03/24/12 10:11 AM
Alberta, Canada eh!
70Cudha Offline
70Cudha  Offline
Alberta, Canada eh!
Cab
P.M. sent to you as we also own a 1969 GTS 383.
Kim
1970 EV2 Barracuda Hardtop
1970 FE5 Barracuda Gran Coupe Convertible
1969 B5 Dart GTS 383
1968 TT1 Barracuda Convertible
1997 Ram SS/T
2008 3500 Ram Diesel
Re: Need help with dates and codes [Re: jmf340] #1201127
03/24/12 10:26 AM
03/24/12 10:26 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
When speaking on date codes you need to keep things in general terms because there always seems to be exceptions whenever someone lays down the law about cutoff dates, trends, "the norm", etc. Be careful what and who you believe on this subject because there is a TON of misinformation handed out on this site and elsewhere.
Various part date codes will vary in respect to the cars Scheduled Production Date on an individual part basis. Some are generally rather close to the SPD, while other parts may vary widely.
In your question you've left out a key ingrediant to helping you, your cars Scheduled Production Date, your VIN sequence is not very helpful in determining date codes on parts.
Post a photo of your cars fender tag or better, your broadcast sheet. Keep in mind that with any of your original parts that are missing you will never know for certain what the codes were or should be, at best you can use tips given here and some educated guesswork and you might get them close enough to be considered "possibly correct" or "acceptably correct" for your particular car.
Re: Need help with dates and codes [Re: ScottSmith_Harms] #1201128
03/25/12 10:19 PM
03/25/12 10:19 PM
jmf340 Offline OP
jmf340  Offline OP
I wish I had the info (fender tag and broadcast sheet) but I don't. I guess I'll just try to make some sense of the info available here and some advice offered by members.
Got Mopar???
