Inexpensive Sonic Tester - Check Cylinder Walls
#1201103
03/21/12 09:58 PM
03/21/12 09:58 PM
Posts: 773 San Antonio, Tx
bulletpruf
San Antonio, Tx
Fellas -
I bought an ultrasonic thickness tester off eBay a few years ago. Chinese and not very expensive.
Problem with it is that the probes they shipped with it were flat and too large for the curve of a cylinder wall, so it would not sit flush on the cylinder wall. Read somewhere that folks were sanding theirs down, so I did that to mine. No luck. Measurements vary fairly significantly now.
Has anyone found a reasonably priced probe that fits one of the Chinese sonic testers? Mine does not have a brand name evident, but figure the attachments are the same.
I realize that the industry standard is the Dakota unit, but I don't have $1,200 to shell out for one of these.
Thanks,
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
Re: Inexpensive Sonic Tester - Check Cylinder Walls
[Re: pittsburghracer]
#1201106
03/22/12 12:07 AM
03/22/12 12:07 AM
Posts: 382 Roseville MN
72swgnr
Roseville MN
True to a point but a person can use anything from snow,plain water,vaseline or ultragel. The thicker gel is mostly for higher temp surfaces and when you need the gel to stay where you put it (like overhead work) The problem with these cheap sonic checkers is that they dont have all the options that a more expensive checker has. For instance, they may only have a couple different options for transducers where as a more expensive unit will have a few dozen options including different frequencies and sizes/profiles. More expensive units will also allow you to use a plastic shoe that goes onto the end of the transducer that you can get in different curvitures. Also to answer your question about finding a different transducer it depends what cable you have. Can you unscrew the transducer from the cable or is the cable and transducer one unit? If its one unit you likely wont beable to buy just any transducer and make it work. Panametrics and krautkramer use different cable types and wont interchance. Also I'm not sure how those chinese meters work as far as calibrating them but you will want to do a high and a low. for example if you are expecting the material to be between .250" and .400" thick make sure you cal. the machine from .500" high and .100" low. A step wedge made of the same material works best for this but also costs quite a bit unless you can make your own. I have seen machines that have issues where they cal. on the high and low perfect but when you check thickness's inbetween the high and low they are WAY off. Anyways these are just some tips and advice that may be useful to some.
[Re: 72swgnr]
#1201111
03/22/12 12:03 PM
03/22/12 12:03 PM
Posts: 17,878 S.E. Michigan
ZIPPY
S.E. Michigan
I have the same setup, and to make it easier to check cylinders I ground and filed a radius into business end of the probe. Did not use anything specific, just did it by eye and feel, but it did help noticeably. Unfortunately when you do that it is no good for flat surfaces anymore, but that is also true of some other brands of testers/probes
Rich H.
Esse Quam Videri
[Re: bulletpruf]
#1201115
03/25/12 02:35 PM
03/25/12 02:35 PM
bulletpruf
San Antonio, Tx
Worst case scenario - I drop $1,200 for the Dakota unit that most shops seem to use. Would take a few years to pay for itself, but it would be a great piece of gear to have in the garage.
Scott
