So anyone try the MSD atomic EFI yet?
#1200491
03/20/12 11:07 PM
03/20/12 11:07 PM
Posts: 9,887 USA
CrAlt
USA
It looks like a well thought out system but I have doubts about replacement sensor availability and pricing? Has anyone tried it on anything yet?
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: So anyone try the MSD atomic EFI yet?
[Re: CrAlt]
#1200493
03/21/12 03:35 AM
03/21/12 03:35 AM
Posts: 649 Davis, California, USA
MrBelvedere2
I am waiting to see if anyone has tried it out too as I am very interested in the system. Definetly seems very well thought out. I saw in one of the new issues of hot rod they had an article about it in the new products section, and they said to keep an eye out as they are going to do a test on one pretty soon. In usual hot rod fashion, it should be a good write up of what to expect.
1965 Plymouth Belvedere II hardtop
[Re: Kern Dog]
#1200495
03/21/12 04:02 AM
03/21/12 04:02 AM
MrBelvedere2
Yeah pretty much is what you are describing. Everything is hidden in the throttle body, TPS,MAP,injectors, etc. What I like is it uses pulse modulation to regulate how much fuel it needs, so you don't need to modify your fuel tank or run a return line. www.atomicefi.com
[Re: CrAlt]
#1200497
03/21/12 11:50 AM
03/21/12 11:50 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
There was another thread on this here at Moparts a few weeks ago...and I shared your concern with parts availability and pricing.
[Re: Kern Dog]
#1200498
03/21/12 11:57 AM
03/21/12 11:57 AM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
I will be putting one on my 73 RR 340 as soon as my body guy is done with it. I want to run E85, which is common around my area, but not across the country. I will be adding their dist and a 6AL box, with this setup i will be able to reprogram it to run reg gas or e85 with just a hand control switch, I talked to MSD quite a long time at SEMA and sounds like this is the perfect setup for me.
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: deansrr]
#1200499
03/21/12 12:20 PM
03/21/12 12:20 PM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
That is one of the draw backs of the EZ-efi. No E85 compatability...I was hoping to see that as a software upgrade, but so far nada...
[Re: deansrr]
#1200504
03/21/12 09:38 PM
03/21/12 09:38 PM
DynoDave
MICHIGAN
If I did this, I would love to have an E85 option, though it's not essential in my application.
I cannot afford one at $2300 but if there were a half-priced alternative it might be hard to resist.
Check out this previous comment...
How about Powerjection III? http://www.professional-products.com/EFI_3.php I have the returnless 70029, but not yet installed
At Summit, the 70026 complete kit is $1683.95. (Not sure what the system differences are between 70026 and 70029)
Summit
[Re: VL21]
#1200506
03/21/12 10:49 PM
03/21/12 10:49 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
You can DIY with GM junk on the cheap... it's just a lot more work to set up
http://grimers.com/vehicles/68wagon/efi/moparefi.php
Maybe all the GM parts worked on his eyes, check out the fuel filter...Chevy speed secret maybe?
Heh, it's very poorly documented and probably pretty old. I bet a MegaSquirt II could control all of those components easily with a lot of community help for the ECU. A MS+junkyard part EFI setup could probably be done for several hundred dollars easily. Heck, forget hacking on crappy GM TBI stuff, get a Magnum intake manifold and its associated top-end hardware and you're already halfway there for a small block.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: CrAlt]
#1200507
03/21/12 10:54 PM
03/21/12 10:54 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Maybe a little off topic but not totally. With the expense of the EFI (which I am exploring also) how much will the system add to the value of the vehicle? If you already have a $20,000 ride and add either the EZ EFI or the MSD will the car be worth $2,000 more with the EFI?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Kern Dog]
#1200508
03/21/12 11:24 PM
03/21/12 11:24 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I read about some EFI system recently that looked exactly like a carburetor. The fuel boals were only covers, there to hide the EFI components. Is this the same setup?
Not sure, but maybe you are talking about Retrotek efi? that was out a few years ago. Horsepower TV put one on a 66 or 67 charger and one of the magazines put it on a car. All I remember is that the magazine guys took it off because they had some issue with it. I think Retrotek is the same as the professional products. While Atomic and EZ efi look sort of like a carb, that Retrotek looks exactly like a carb.
[Re: CrAlt]
#1200510
03/22/12 11:44 AM
03/22/12 11:44 AM
deansrr
NW Indiana
I talked to MSD yesterday and will need Dist 8534, rotor 84211, 6A box (and yes send in rebate for it) and the Atomic kit2910, I already have fuel pump and lines done already. My warehouse is having a sell March 26-28, so I will be curiuos how much I will save. My car is suppose to be back the end of April so it won't be till May till I can put it on.
1973 Road Runner
1973 240z (wifes)
2002 Honda S2000
