advantages of electric fuel pump
#1200325
03/20/12 05:14 PM
03/20/12 05:14 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Im having a FAST legal stroker 340 built for my 71 roadrunner. Just wondering what everyones thoughts were of electric fuel pump vs. mechanical for this application. If I were to do electric, Id probably get a in-tank pump. I know vapor lock would be a worry with mechanical, but if the motor keeps around 180*, it wouldn't be a problem, right? thanks in advance! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: advantages of electric fuel pump
[Re: mopars_1]
#1200326
03/20/12 05:21 PM
03/20/12 05:21 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
Better to have the weight in the back, even if its just a little!
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: bodyworks racing]
#1200328
03/21/12 12:05 PM
03/21/12 12:05 PM
mopars_1
Ridgeland Wi
thanks for the responses. anyone else want to chime it? thanks! -kevin
[Re: Dodgem]
#1200330
03/21/12 12:46 PM
03/21/12 12:46 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
advantages are many, one not listed yet, is no more cranking the engine to prime the fuel bowls if the engine has been sitting for awhile. just let the pump run to fill the bowls.
one disadvantage is that if you do not have your pressure set properly with a regulator, you can push fuel past the needle and seat, and you'll flood the engine, wash down cylinder walls and kill your rings.
**Photobucket sucks**
[Re: emarine01]
#1200332
03/21/12 10:58 PM
03/21/12 10:58 PM
mopars_1
Ridgeland Wi
no support for mechanical? anyone want to play devils advocate?
