Re: Float Level Affects On Fuel Curve
[Re: lewtot184]
#1200105
03/20/12 12:05 PM
03/20/12 12:05 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
""I'd use the air bleeds to effect the fuel curve not the float level""
I am about as close as I can get with my bleeds and now I am looking for an external adjustment that can be tweaked before opening up the carb. If I could tweak .2/.4 on the A/F gauge by turning the Primary or the Secondary float by 1/8 or 1/4 of a turn, then I might try testing that and see what happens. But if adjusting one float only screws up too many other things, then that would not be the way to go. Thanks for the response.
-------------------------------------------- Does the Primary bowl fuel level affect only the Primary circuit? Does the Secondary bowl fuel level affect only the Secondary circuit?
If so, then I should be able to tweak the P or the S circuit slightly by only adjusting the corresponding float. Is this correct?
I don't like to set my floats any lower than the bottom of the glass and I don't like to set them any higher than the middle line. If this is correct, then once the carb is setup fairly close inside (jets, pv, internal bleeds, etc.), then I should be able to use my float adjustments to fine tune the A/F of the P circuit and the S circuit "separately" as long as my float levels are in between the bottom of the sight glass and the middle line in the sight glass.
I would have to reset my idle A/F mixture after each float adjustment, which is no biggy.
What else am I missing?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1200106
03/20/12 04:42 PM
03/20/12 04:42 PM
Posts: 1,686 Philadelphia
radar
Philadelphia
Oh man
I've read and contributed to some of your tuning threads before and I have learned from experience here to watch out asking detailed holley questions-
for example:
Before I knew how to tune using idle feed restrictions nobody had any suggestions about how to lean out the off idle cruise performance. After I had done some research and tuning with wires etc (coulda bought HP blocks, but Im cheap) I saw major improvement and THEN started hearing about "well the first thing to do for a street driven double pumper is limit the IFRs until the idle mix screw (a misnomer I now know) is correct around 1.5 turns"
It's like when you learn a new word and start hearing and seeing it everywhere right after, except around here if it's a hard word no one wants to teach it to you- they only wanna debate pronunciation after you already know the spelling and definition!
Sorry for complaining- but I kinda doubt you'll get the answer you're looking for. Probably lots more 'try the air bleeds first'. I'm not trying to flame anybody's answers above, they're just trying to help and most Qs around here aren't really looking for an in depth answer.
Having said all that, I know you are chasing a perfect tune with the least amount of compromise possible. I've read some of your posts and watched you learn and experiment. I am no guru or 20 yr veteran tuner (you're way ahead of my efforts already) but I do know that once you know all the user tunable stuff (jets, power valves, acc. pump stuff), and the 'expert tuner' stuff (air bleeds, idle feed restrictions) you might still have to hack at it some (wires or custom jets to tune power valve channel restrictions, drilling butterflies) and sometimes that stuff still won't get you the efi-like drivability you're after. At that point you should be chasing perfection because if you still don't have the basics down and you're hacking up a good carb you're just going deeper into the woods.
I think you are at that point where the magical and mysterious science of fluid dynamics goes way way past my education and gets into the realm of tinkering and datalogging with a-b-a testing. I think you should try different float settings out- what could it hurt? The level is definitely related to the drilled emulsion holes and all that fancy stuff on the metering block. You probably know that some 'trick' blocks and some stock blocks have different patterns of holes. I don't pretend to understand it well enough to explain it, but on the most basic level I'm sure that a higher float will make a richer mix. Once you get away from the stock level you run the risk of getting into other problems that can't be tuned out, but that's all part of the fun right? Then you drive up into another elevation, or weather/temp change and everything is all wrong all over!
I said my 750 DP was good enough when I got good WOT/launch, decent manners and mileage (sorta), and don't foul plugs in traffic, but I have MUCH respect for your efforts. Sorry for writing a novel here- Good luck with your tuning I'd be interested to hear how you make out.
rdr
[Re: radar]
#1200107
03/20/12 05:06 PM
03/20/12 05:06 PM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
I have messed around with adjusting float level to enrich or lean out the fuel curve. Basically what you are doing is covering up or uncovering the emulsion passages on the metering block, which in theory will change the "tilt" of the curve. This is a good explanation on the subject: http://www.quickfueltechnology.com/technical-info/emulsionMy experience has been that if you drop the float level down to the point to leaning the transition it will be too low and potentially cause fuel boiling issues, high speed starvation, flat spots while cornering. On the contrary if you have the float level high enough to enrich the circuit you can experience spill-over, fuel siphoning, or dribbling booster syndrome. This is the reason they sell emulsion bleeds. If you have the air bleeds as close as you can get them you could make very small changes in float level and see if you can sneak up on it. Most of my testing has been at 4200' altitude so your mileage may vary. Let us know what you find.
[Re: radar]
#1200109
03/20/12 09:35 PM
03/20/12 09:35 PM
YO7_A66
Indiana
I have allot of fun tinkering with my carbs. All I know is that the more I tinker, the better the car runs and the more I learn. The O2 sensors are very addictive and a great tuning tool. I am still looking to see if anyone has messed with tuning each bowl level seperately instead of keeping them both set at the same level. I will start messing with it after my next test drive to see if small increments (1/12, or 1/8 of a turn or so) will tweak the main or tweak seconds in the direction that I need.
Thanks for the responses.
[Re: YO7_A66]
#1200111
03/20/12 11:43 PM
03/20/12 11:43 PM
Posts: 598 NC, USA
davenc
NC, USA
My two cents....
The primary and secondary circuits in the carb are independent but may both affect fuel distribution in the manifold. Leaning/richening one side of the carb to get to a specific AFR on a gauge might lead to some cylinders being out of balance. Determining cylinder to cylinder AFR with a wideband is not really possible from what I understand. You may see some fluctuation but the sensor is always doing some measure of averaging.
I don't see anything bad about experimenting in itself. Persistence and willingness to explore can lead to new insights. However, it is important to arm yourself with as much understanding as possible in order to look out for and understand the potential consequences with any change. There are many good points in the other posts here.
Small changes in float level can have an effect on the AFR over the entire operating range of the carb, although perhaps not to an equal degree (ie idle, transition, main). Because of this common wisdom is to set float level first, then tune the different circuits. If float level is later changed, then some of the other tuning items may need to be tweaked again.
Tweaking the idle is easy but not so on the other circuits. If you are looking to adjust just a portion of the fuel curve, float adjustments may produce nothing but frustration.
That said, I have never tired to set the P and S floats differently.
[Re: davenc]
#1200112
03/21/12 09:18 AM
03/21/12 09:18 AM
YO7_A66
Indiana
""yes the bowl levels only affect the circuits on the side of the carburetor they're on.""
""The primary and secondary circuits in the carb are independent but may both affect fuel distribution in the manifold. Leaning/richening one side of the carb to get to a specific AFR on a gauge might lead to some cylinders being out of balance."" ------------------------------------------------------------------------------------------------------------------------------------
Thank you both for these responses.
I always try to get both bowls as close I can to each other but they have never been exact. If they are both close to each other, than I call it good. The adjustments that I am considering would only be within a half of a turn or so from each other since I am so close to the numbers that I want. This is a consideration due to that fact that the floats can be adjusted in minute distances due to the threaded adjusters on the needle/seat assemblies. I might give it a try just to see if I can move the A/F gauge by .2-.4 or so just on the primary side or just on the secondary side and note what happens. I also understand the changes that the weather creates on the A/F numbers and this is another reason why I am considering using the external adjustment of the floats.
Thanks allot for all of the replies.
[Re: YO7_A66]
#1200115
04/12/12 10:26 AM
04/12/12 10:26 AM
YO7_A66
Indiana
I have been playing around with the float levels again and I have found that I can "tweak" the cruise A/F with the front float level and I can "tweak" the WOT A/F with the secondary float level. I do have to reset the metering screws after the float setting changes to keep the in-D A/F the same. I started both float settings in between the bottom of the sight glass and the halfway mark (apx 1/3 up the glass) while getting my cruise A/F and my WOT A/F tuned. Now what I have found out is that as the weather changes, I can adjust the A/F numbers by just turning one float or the other by as little as about 1/12 of a turn. Our weather changed 30 degrees in one week, and all I did was about 1/10-1/12 of a turn to each float and my A/F readings fell back into place. Keep in mind that I am cruising on the edge of lean with my combo. Once my cruise numbers rise past 15.0, then I readjust the front float up and my numbers fall back into the 14's where I know that I am safe. If I went into the low 14's at cruise, then I might not have to worry about the weather change so much, but since I now know what it takes to correct it, I just make a quick change before I start up the car when the outside temperature shifts in large amounts, then I am ready to go.
Note: I can do this now that I have my cruising and WOT A/F numbers where I want them.
Note: I currently have both floats about the same height. They are both about 1/16" above the bottom of the sight glass's and my metering screws are all still equal. Even if they were a "little" different from front to back, I can't see why this would hurt anything as long as the A/F numbers were coming out where they need to be.
[Re: YO7_A66]
#1200117
04/12/12 12:40 PM
04/12/12 12:40 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You're trying to find a .2 adjustment on the A/F curve with a carburetor?
The easiest way to do it is to wait for the weather to change.
Once you get it perfect, the temps will increase, humidity will change, and the barometric pressure will increase. When that happens you get to do it all over again.
If you must have perfection then go EFI. Should that not be an option be prepared to retune the carb after every 8 degree change in temperature or 10% change in humidity.
[Re: feets]
#1200118
04/12/12 01:18 PM
04/12/12 01:18 PM
YO7_A66
Indiana
.2 is not enough for me to worry about but adjusting the floats by 1/10 or 1/12 of a turn is a quick way to gain .4 or so if needed as the weather changes drastically. To those of us who want to run carbs & O2 sensors, this is an easy way to make the adjustments per the weather. I am not expecting the perfect universal tune. I am just showing that small adjustments can be easily made without tearing into the carb every time the weather changes.
