3.8 water pump #1200097
03/20/12 08:56 AM
03/20/12 08:56 AM
SD
Z
zrxkawboy Offline OP
Z
SD
How difficult is it to replace the water pump on an 05 T&C 3.8? Thanks!
It's Swifty! Swifty, you toad sucker!
Re: 3.8 water pump [Re: zrxkawboy] #1200098
03/20/12 09:20 AM
03/20/12 09:20 AM
crlush Offline
crlush  Offline
Not bad, I had to put a jack under motor a unscrew motor mount then drop motor down to get it out and back in, probly 1/4 inch more room and it would have just fell out.
