65 Coronet with poly 318 and cable shift TF #1199980
03/19/12 11:42 PM
03/19/12 11:42 PM
Ft. Worth Texas
Fredmopar Offline OP
Ft. Worth Texas
Any other motors bolt to this tranny other than old "A" block 318? Adapters available? Any help appreciated. Anyone near Ft. Worth with a big block cable shift tranny for sale? Parts to beef up the old 318 almost impossible to find.
Re: 65 Coronet with poly 318 and cable shift TF [Re: Fredmopar] #1199981
03/20/12 12:32 AM
03/20/12 12:32 AM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
I'm 99 percent certain an LA motor will bolt up. As for the poly, I think somebody makes a 4bbl intake. Cam would need to be custom made. As for the bottom end, it's still basic smallblock, so a stroker crank can be done.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: 65 Coronet with poly 318 and cable shift TF [Re: 75DART440] #1199982
03/20/12 06:24 AM
03/20/12 06:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The LA bolts right up.The 66 Chargere my kid has we pulled the poly and put in a 70 LA.You will need to change exhaust also as poly is totally different.I believe one bolt dosent line up on the bell.Thats it.Rocky
Chrysler Firepower
Re: 65 Coronet with poly 318 and cable shift TF [Re: therocks] #1199983
03/20/12 08:26 AM
03/20/12 08:26 AM
Andrewh Offline
Andrewh  Offline
any la or magnum bolts up.
I have a 5.9 mag running in my 65 coronet using the original 727 from a poly 318.
Re: 65 Coronet with poly 318 and cable shift TF [Re: Fredmopar] #1199984
03/20/12 11:41 PM
03/20/12 11:41 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
There are adapter kits to go BB to SB transmissions so they are available if you want to go that route
http://smrtrans.tripod.com/smrtransmissionsintro/id9.html
904 is the same bell housing as a SB 727
Re: 65 Coronet with poly 318 and cable shift TF [Re: Dodgem] #1199985
03/21/12 02:35 AM
03/21/12 02:35 AM
Ft. Worth Texas
Ft. Worth Texas
Thank you one and all. The info is a tremendous help.
