71 b-body master cylinder. studs or bolts??
#1199301
03/18/12 11:10 PM
03/18/12 11:10 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
my 71 roadrunner has the standard manual drums (no power) is the master cylinder held on by bolts that go through the firewall? or is it held on by studs that are pressed into the brake pedal assembly? mine had 3" long 5/16s bolts with a crap ton of washers... pretty sure factory didn't do that haha. any help is appreciated. thanks! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: 71 b-body master cylinder. studs or bolts??
[Re: mopars_1]
#1199302
03/19/12 12:23 AM
03/19/12 12:23 AM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
you already have the answer ![](/ubbthreads/images/graemlins/smile.gif)
[Re: 440beep]
#1199305
03/19/12 09:20 PM
03/19/12 09:20 PM
Posts: 562 New York
EL5 71
New York
Actually, they are studs with the letter "M" on the head that press into the master cylinder and the nuts with lock washers are tightened from under the dash. You really don't have to have them pressed into the master, you can just draw them in while tightening if you're careful and take your time. Here's an original set from my 71 Charger R/T 440 with Manual Drum brakes. Eddie
[Re: EL5 71]
#1199307
03/19/12 11:44 PM
03/19/12 11:44 PM
mopars_1
Ridgeland Wi
thank you, I appreciate it. if by chance you have another set, would you sell it?
[Re: flypaper]
#1199309
03/20/12 09:59 PM
03/20/12 09:59 PM
mopars_1
Ridgeland Wi
those are the studs above the master cylinder. Im thinking by EL5 71's post, they arn't the same. thanks though! -kevin
[Re: mopars_1]
#1199310
03/20/12 10:03 PM
03/20/12 10:03 PM
flypaper
I hate Texas
I hate Texas
jersey shore
then they are bolts/nuts those are the only studs off of that housing it was a good while since i ripped it apart i know have them bagged and tagged somewhere ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: mopars_1]
#1199315
03/20/12 10:46 PM
03/20/12 10:46 PM
flypaper
I hate Texas
I hate Texas
jersey shore
save it! i don't want to sell it ![](/ubbthreads/images/graemlins/laugh2.gif) i want it for my junk,i worked for a master cyl rebuilder many years ago so i can rebuild it myself and even sleeve it if need be.
[Re: mopars_1]
#1199319
03/20/12 11:50 PM
03/20/12 11:50 PM
flypaper
I hate Texas
I hate Texas
jersey shore
i have 99% of every nut,bolt, clip and a ton of nos for one of my 2 71 rr's more then the car will ever be worth ![](/ubbthreads/images/graemlins/image_294343.gif) i can't go to 98% ![](/ubbthreads/images/graemlins/laugh2.gif) seriously try moparmark here or try this one that just surfaced yesterday.
http://www.forbbodiesonly.com/moparforum/showthread.php?t=32100
you now have pics of the exact correct parts you need
understood. thanks very much for taking the time to help! I very much appreciate it. ![](/ubbthreads/images/graemlins/smile.gif)
btw, IF you ever decide to sell them..
i was extremely lucky to trip over and buy a unadvertised 71 sat parts car while hunting for parts. i had 9 sec phill on here drag it back to me out of upstate ny. it was 99% unmolested/untouched under the hood except for the batt and rad cap/plug wires.. the only thing that was messed with was the dash wiring. i probably should of taken a ton more underhood detail pics then i did it was a rats nest of vaccum lines and wires under there ![](/ubbthreads/images/graemlins/laugh2.gif) i do have a bunch ![](/ubbthreads/images/graemlins/tongue.gif)
![](http://i26.photobucket.com/albums/c144/flypaper38/71%20sat/010.jpg)
![](http://i26.photobucket.com/albums/c144/flypaper38/71%20sat/005.jpg)
