71 b-body master cylinder. studs or bolts?? #1199301
03/18/12 11:10 PM
03/18/12 11:10 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
my 71 roadrunner has the standard manual drums (no power) is the master cylinder held on by bolts that go through the firewall? or is it held on by studs that are pressed into the brake pedal assembly? mine had 3" long 5/16s bolts with a crap ton of washers... pretty sure factory didn't do that haha. any help is appreciated. thanks!
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199302
03/19/12 12:23 AM
03/19/12 12:23 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you already have the answer
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199303
03/19/12 12:57 AM
03/19/12 12:57 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Alright, thanks. Not sure why somebody would press out them studs.
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199304
03/19/12 09:51 AM
03/19/12 09:51 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
yes to put in a brake booster for powerbrakes
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 71 b-body master cylinder. studs or bolts?? [Re: 440beep] #1199305
03/19/12 09:20 PM
03/19/12 09:20 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Actually, they are studs with the letter "M" on the head that press into the master cylinder and the nuts with lock washers are tightened from under the dash. You really don't have to have them pressed into the master, you can just draw them in while tightening if you're careful and take your time. Here's an original set from my 71 Charger R/T 440 with Manual Drum brakes. Eddie
Re: 71 b-body master cylinder. studs or bolts?? [Re: EL5 71] #1199306
03/19/12 09:37 PM
03/19/12 09:37 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Looks like I'm gonna have to make my photos alot smaller before I can get them posted. Gotta work tonight but I'll try to have them on here tomorrow for you Kevin. They are a unique stud and pretty tough to come by without the usual rust pitting damage. The photos I have are of a flawless set so you'll know what you're looking for. Eddie
Re: 71 b-body master cylinder. studs or bolts?? [Re: EL5 71] #1199307
03/19/12 11:44 PM
03/19/12 11:44 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thank you, I appreciate it. if by chance you have another set, would you sell it?
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199308
03/20/12 09:55 PM
03/20/12 09:55 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
this is from a 71 sat with drum brakes
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199309
03/20/12 09:59 PM
03/20/12 09:59 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
those are the studs above the master cylinder. Im thinking by EL5 71's post, they arn't the same. thanks though!
-kevin
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199310
03/20/12 10:03 PM
03/20/12 10:03 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
then they are bolts/nuts
those are the only studs off of that housing
it was a good while since i ripped it apart
i know have them bagged and tagged somewhere
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199311
03/20/12 10:10 PM
03/20/12 10:10 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
if you can find the factory master cylinder with the studs, Ill buy them!
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199312
03/20/12 10:37 PM
03/20/12 10:37 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you made me look
studs and nuts
nuts
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199313
03/20/12 10:40 PM
03/20/12 10:40 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199314
03/20/12 10:42 PM
03/20/12 10:42 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
pm sent
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199315
03/20/12 10:46 PM
03/20/12 10:46 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
save it!
i don't want to sell it
i want it for my junk,i worked for a master cyl rebuilder many years ago
so i can rebuild it myself and even sleeve it if need be.
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199316
03/20/12 10:51 PM
03/20/12 10:51 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
save it!
would you sell the studs? maybe trade?
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199317
03/20/12 11:24 PM
03/20/12 11:24 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i have 99% of every nut,bolt, clip and a ton of nos for
one of my 2 71 rr's more then the car will ever be worth
i can't go to 98%
seriously
try moparmark here or
try this one that just surfaced yesterday.
http://www.forbbodiesonly.com/moparforum/showthread.php?t=32100
you now have pics of the exact correct parts you need
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199318
03/20/12 11:31 PM
03/20/12 11:31 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
i can't go to 98%
seriously
understood. thanks very much for taking the time to help! I very much appreciate it.
btw, IF you ever decide to sell them..
1937 Plymouth PT50
Re: 71 b-body master cylinder. studs or bolts?? [Re: mopars_1] #1199319
03/20/12 11:50 PM
03/20/12 11:50 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i can't go to 98%
seriously
i was extremely lucky to trip over and buy a unadvertised 71 sat parts car
while hunting for parts.
i had 9 sec phill on here drag it back to me out of upstate ny.
it was 99% unmolested/untouched under the hood
except for the batt and rad cap/plug wires..
the only thing that was messed with was the dash wiring.
i probably should of taken a ton more underhood detail pics
then i did
it was a rats nest of vaccum lines and wires under there
i do have a bunch
Re: 71 b-body master cylinder. studs or bolts?? [Re: flypaper] #1199320
03/22/12 07:41 PM
03/22/12 07:41 PM
New York
E
EL5 71 Offline
EL5 71  Offline
E
New York
Here's a few pics of the assembly line studs and nuts.
