B-body rear end question #1198396
03/17/12 02:02 PM
03/17/12 02:02 PM
SoCal
jake4cars Offline OP
SoCal
1969 B-body with slant 6 and manual trans, were they all 8 3/4 rears?
Thanks,
Joey
Re: B-body rear end question [Re: jake4cars] #1198397
03/17/12 03:05 PM
03/17/12 03:05 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: B-body rear end question [Re: 340SHORTY] #1198398
03/17/12 04:01 PM
03/17/12 04:01 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It COULD have been an 8 1/4"! They were phased in late '69. My '70 318 Charger had am 8 1/4" axle. They are also listed in the '69 Plymouth factory service manual.
If it is an 8 3/4" and is original, it may have the small 1 3/8" pinion '741 case. TRY to get gears or a SG for THAT oddball!
Re: B-body rear end question [Re: Kern Dog] #1198399
03/17/12 04:45 PM
03/17/12 04:45 PM
SoCal
SoCal
Yeah, I am just curious as I am buying a B-body out of a junkyard and it is sitting in the ground too much to differentiate until I get it up on the trailer.
Joey
Re: B-body rear end question [Re: jake4cars] #1198400
03/17/12 05:33 PM
03/17/12 05:33 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Not sure about '69, but my '67 Belvedere, slant-6/3-spd has a 7-1/4.
It's Swifty! Swifty, you toad sucker!
Re: B-body rear end question [Re: zrxkawboy] #1198401
03/18/12 03:46 AM
03/18/12 03:46 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Slant six cars would have a 7 1/4.. Stay away..
Unless someone broke the old rear and swapped in an 8 3/4.
Re: B-body rear end question [Re: sthemi] #1198402
03/18/12 09:38 AM
03/18/12 09:38 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
my friend has a 68 coronet w/ /6-3sp. it had a 7 1/4" rear in it.
Re: B-body rear end question [Re: jake4cars] #1198403
03/18/12 07:38 PM
03/18/12 07:38 PM
I think 1970 was the first year of the 8 1/4 maybe not I knew a guy that had a 1970 Charger Vitamin C car with a slant six automatic trans and a rear end that had the rear inspection cover,it was not a Dana 60
Re: B-body rear end question [Re: Cab_Burge] #1198404
03/19/12 05:28 PM
03/19/12 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
'69 was the first year for the 8 1/4" but they were mostly used behind small V8's (318, 383-2). The 7 1/4" is more likely to be found in a /6 car.
Re: B-body rear end question [Re: jake4cars] #1198405
03/19/12 06:02 PM
03/19/12 06:02 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
What's left of the one in my side yard has a 7-1/4" under it.
Everybody makes fun of a hillbilly until they need something fixed
Re: B-body rear end question [Re: Kern Dog] #1198406
03/19/12 06:05 PM
03/19/12 06:05 PM
Almost Heaven
B_Body_Bob Offline
Master of nothing
B_Body_Bob  Offline
Master of nothing
Almost Heaven
Sure grip is interchangable for all 8-3/4s. Bearings for the SG are different between cone and clutch type but it's the ID that's different, they're the same as far as the case goes. I took one from a 741 and put it in a different case. Still have the case and gears from the 741, should probably scrap it.
