440 Source Water Pump and Housing #1197950
03/16/12 01:14 PM
03/16/12 01:14 PM
Alberta, Canada
camd Offline OP
camd  Offline OP
Alberta, Canada
Hey Everyone,
Not on here posting very much, but always following and reading. Im in the process of freshening up a 400 out of my 78 Magnum. I have a question about how good the 440source aluminum water pump housings and water pumps are. I will be wanting the passenger side inlet housing. Any input would be great!
Cam
Re: 440 Source Water Pump and Housing [Re: camd] #1197951
03/16/12 01:39 PM
03/16/12 01:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
There has been some moaning about the size of one of the passages on the "drivers side inlet" castings. I just hogged that passage out on the one I have as there's plenty of material in that area - it took all of ten minutes to do. Otherwise the casting is nice and fits fine. For the price you really can't beat it.
Re: 440 Source Water Pump and Housing [Re: Stanton] #1197952
03/16/12 02:00 PM
03/16/12 02:00 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
If they are still using the Cat water pump ??
It is a High Volume but only at higher RPM, not at idle where I needed it on my Challenger
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: 440 Source Water Pump and Housing [Re: Stanton] #1197953
03/16/12 02:37 PM
03/16/12 02:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did the thermostat housing bolt spacing get corrected ?
Otherwise the OP really has no alternative choice if he wants something other than the stock iron housing .
Re: 440 Source Water Pump and Housing [Re: camd] #1197954
03/16/12 02:45 PM
03/16/12 02:45 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Do what I did and get the Cat housing. I got it from KMJ performance $69 shipped. I used a stock replacement pump and thermostat housing from Napa. It all bolted up nicely with no leaks. I run it on 100 degree days in traffic and stay at 180.
Re: 440 Source Water Pump and Housing [Re: camd] #1197955
03/16/12 05:00 PM
03/16/12 05:00 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Cheap China junk...
Internal passages too small, will make an engine run 20-30 degrees hotter...
Also the casting height is different from the OE Mopar aluminum one, forces one to use different spacers to get the proper fan belt/pulley alignment.
May work OK for a casual cruiser but dump it if one has built the motor and/or lives in a hot climate.
Just my $0.02...
Re: 440 Source Water Pump and Housing [Re: Sinitro] #1197956
03/16/12 06:00 PM
03/16/12 06:00 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Mine lined up perfect and cools my stroker motor just fine, all summer long.
Re: 440 Source Water Pump and Housing [Re: GTXKen] #1197957
03/16/12 08:58 PM
03/16/12 08:58 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Awesome...
Glad it worked fine for you..
How hot does it get in the summertime in Indiana?
We ran 1 for about a month on our 520 inch stroker, the temperature ran well about 210 degrees. Pulled it off, installed the Mopar OE water housing and temperature dropped 25 degrees..
We sold it for $25 @ last year's Spring Fling
Just my $0.02..
Re: 440 Source Water Pump and Housing [Re: Sinitro] #1197958
03/16/12 09:22 PM
03/16/12 09:22 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Had the same setup...I sold it last year brand spanking new for $100 because I didn't want to be a statistic....Do so at your own risk. I went balls out and got the real one from Mancini with the matching HV water pump
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 440 Source Water Pump and Housing [Re: camd] #1197959
03/16/12 10:43 PM
03/16/12 10:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
See, told ya there'd be moaning !!!
Re: 440 Source Water Pump and Housing [Re: Stanton] #1197960
03/16/12 10:48 PM
03/16/12 10:48 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
I've heard of several people running the smaller passage 440source housing with a good water pump. And it worked great. Seems the 440source pump is more of the problem than the housing.
Re: 440 Source Water Pump and Housing [Re: 440forPOWER] #1197961
03/17/12 04:39 AM
03/17/12 04:39 AM
808CUDA Offline
808CUDA  Offline
The pump is the issue. I ran both the 440 Source housing and pump and ran hot at lights. Installed a Milodon HV pump and ran 20 deg cooler.
Re: 440 Source Water Pump and Housing [Re: 808CUDA] #1197962
03/17/12 04:41 AM
03/17/12 04:41 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
I read about the issues had with the 440source water pump and housing combo on here... I decided to get the waterpump kit from mancini that they have made, came with the pump, housing, and chrome water neck for $140. The motor hasn't been ran yet, but the passages are good sized and I like the looks of it
Re: 440 Source Water Pump and Housing [Re: 808CUDA] #1197963
03/17/12 08:00 AM
03/17/12 08:00 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Yes, it was the pump not the housing. That's why I used the napa pump. I edited my last post. I got the housing from KMJ performance.
Re: 440 Source Water Pump and Housing [Re: ireland383] #1197964
03/17/12 02:04 PM
03/17/12 02:04 PM
Utah, USA
1964superstock Offline
Utah, USA
So who makes the best performing mechanical high volume water pump for big block chryslers? Is the aluminum water pump from Mopar Performance considered to be the best?
http://www.summitracing.com/parts/DCC-5007643/
Re: 440 Source Water Pump and Housing [Re: 1964superstock] #1197965
03/17/12 03:06 PM
03/17/12 03:06 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Running the 440 Source housing with the MP pump. Cools fine.
'71 SSP - SOLD!
Re: 440 Source Water Pump and Housing [Re: Mobarge] #1197966
03/17/12 04:07 PM
03/17/12 04:07 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Had the 440 source houseing and there pump car ran over 210. Trashed the pump and installed a Milodon pump runs 185 all day now. Still a little hotter then it ran with stock houseing and stock pump. If i ever have to pull it apart again i'll hog out the pasages. They are half the size of OEM houseing.
Re: 440 Source Water Pump and Housing [Re: Dougsmopars] #1197967
03/17/12 04:18 PM
03/17/12 04:18 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Had a 440source pump and housing on my 511" stroker street engine and it always ran cool with lots of street miles on it. Including long highway cruises where insufficient water movement usually presents itself.
2 kids and a dog
