New 6.7 cummins #1197394
03/15/12 02:57 AM
03/15/12 02:57 AM
PA
W
w7smallblock Offline OP
W
PA
Does anyone know if the 350/800 cummins is the same as the 350/650 with just a diff. factory ECU flash?
Re: New 6.7 cummins [Re: w7smallblock] #1197395
03/15/12 12:44 PM
03/15/12 12:44 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Yes it is all in the software. It depends on body style (cab and chassis, 1 ton, etc) and most importantly what trans is behind the engine. The Aisin trans equipped chassis get the big tune.
Re: New 6.7 cummins [Re: teflon] #1197396
03/16/12 01:39 AM
03/16/12 01:39 AM
PA
W
W
PA
Are you sure about this? It shows on the website that the 2500,3500 with auto make 350/800 and the chassis cabs with the Aisan trans only make 305/610
Re: New 6.7 cummins [Re: w7smallblock] #1197397
03/16/12 03:05 PM
03/16/12 03:05 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
68RFE used in 350/800 applications in pick-ups. Aisin transmissions are put in C&C trucks.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
