3 speed wiper motor switch test #1196743
03/14/12 12:52 AM
03/14/12 12:52 AM
AZ - The "dry heat" state
71autoxr Offline OP
71autoxr  Offline OP
Maybe I'm missing something here. I have a problem with my variable speed wiper motor or switch. The FSM has a test sequence for the switch which includes terminals R1and R2 which the switch does not have. The switch and motor are correct for the application (69 dart) as is the wiring. The motor works with the switch including parking and the washer pump. After using the wipers the motor begins to make a noise as though it is attempting to turn on. After a few seconds the switch clicks and the motor noise stops. This will continue until the key is turned off. My first question is what are the R1 R2 within the test chart? Second question is why the noise from the motor and switch?
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: 3 speed wiper motor switch test [Re: 71autoxr] #1196744
03/14/12 01:17 AM
03/14/12 01:17 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Do a search this was just answered.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
