Vacuum vs mechanical secondary
#1195808
03/12/12 05:24 PM
03/12/12 05:24 PM
Posts: 7,843 Spring Mount, PA
MOPAULY
Spring Mount, PA
Need to purchase a carb soon for the 340 on my '72 Charger and am undecided between a vacuum or mechanical secondary 650. I previously ran a mechanical 650 but would like to squeak a little better fuel mileage out if possible; if there is no real gain I'll go mechanical again, what are you successfully running on the street?
The motor is a 340 .030 over with the MP .484 HD cam, 904, and 4.30's in the rear.
Re: Vacuum vs mechanical secondary
[Re: gch]
#1195811
03/12/12 10:30 PM
03/12/12 10:30 PM
[Re: MOPAULY]
#1195812
03/12/12 11:19 PM
03/12/12 11:19 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Dare I say-750 Edelbrock Thunder series (AVS). The cruise setting is much more tunable (step up rods and springs), and the accelerator pump doesnt dump as much fuel, plus its mechanical that acts like a vacuum secondary (air valve on secondaries). If you were racing it I'd say a Holley style double pumper all the way.
[Re: torkrules]
#1195813
03/13/12 02:20 AM
03/13/12 02:20 AM
Posts: 805 Eastern WA
ProStock1320
Eastern WA
My vote goes to the vacuum secondary carb. If you go Holley, buy the pop-top pod and change springs if want to tune further. Let the engine tell the carb what it needs - especially for street use. My outside the box (or outside my mind ![](/ubbthreads/images/graemlins/biggrin.gif) ) suggestion would be a Thermoquad - small primaries for what little bit of economy you'll get with your combo & giant secondries to let that thing eat. If you really want to spend some coin, consider EFI - either thru a throttle body on top or multi-port. ![](/ubbthreads/images/graemlins/drool5.gif)
[Re: gch]
#1195814
03/13/12 12:23 PM
03/13/12 12:23 PM
MOPAULY
Spring Mount, PA
You have the .484 cam and 4.30 gears and you want more mpg?REALLY?!
Vacuum is better bet I would be looking a spreadbore anything.
The 4:30's will most likely be swapped for a set of 3:23's
[Re: MOPAULY]
#1195815
03/13/12 12:47 PM
03/13/12 12:47 PM
Posts: 9,838 Detroit, Michigan, USA!
peelerboy
Running a purple stripe .484 cam will pretty much defeat any attainable fuel economy for that car & engine combo. (small V8 in a large car) That's an extremely inefficient cam for any sort of attempt at hyper-miling. There will be no discernible mileage difference between a mechanical and vacuum secondary square-bore carb. Although, you might see a pinch better economy with a spreadbore AND if your driving habits reflect a legitimate desire for success by keeping your foot out of it. (which I personally have a really hard time doing when driving my Challenger) ![](/ubbthreads/images/graemlins/tongue.gif) Dale
[Re: MOPAULY]
#1195817
03/13/12 01:14 PM
03/13/12 01:14 PM
peelerboy
Vacuum actuated secondaries do nothing more than slow the speed at which the rear butterflies open under full acceleration. Comparing apples to apples (square bore mechanical 650 vs. square bore vacuum), there will be no mpg difference while practicing conservative driving habits.
But if you were to turn up the heat to a slightly "spirited" style of driving, the vacuum setup with definitely squeak out superior economy because it's not delivering as much fuel. At the same time, the car will be less responsive. It's all a series of trade-offs. If you're not seeking every last ounce of performance from this car, I'd go with the carb with vacuum secondaries.
[Re: 383man]
#1195822
03/13/12 07:57 PM
03/13/12 07:57 PM
I would not go to 3.23 gears with the .484 cam in the car. Ron
Really?
I've had good luck using both in combo.
Ran a little 318 into the 14's at 95mph on street tires and pulled down 17 mpg at the same time. Not stellar numbers but it was a wore out, re-ringed 318 that probably had 7.5:1 CR if I was lucky!
I always had plenty of low end torque, even with a single plane M1 intake. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 383man]
#1195824
03/13/12 11:24 PM
03/13/12 11:24 PM
It was late 90's and I had a 2800 stall convertor. 3,260 lbs. of car and 195 lbs of me. ![](/ubbthreads/images/graemlins/laugh2.gif)
