Jesel Belt Drive, Installation instructions? #1195773
03/12/12 03:20 PM
03/12/12 03:20 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi.
Just recieved the above but it's come with no instructions . I've found installations guides for BBC and Ford stuff but no Chrysler stuff.
Any pitfalls to look out for? Any clearance issues with KB blocks?
TIA.
Tig
Re: Jesel Belt Drive, Installation instructions? [Re: Tig] #1195774
03/12/12 03:27 PM
03/12/12 03:27 PM
AndyF Offline
AndyF  Offline
There should be instructions on the Jesel website. If not, just download the instructions for the BB Chevy unit. The Mopar belt drive is almost identical to the BB Chevy belt drive. Both kits share most of the part numbers.
You might need to grind some clearance in the block. Best to mock things up before you install on a finished shortblock.
Re: Jesel Belt Drive, Installation instructions? [Re: AndyF] #1195775
03/12/12 05:26 PM
03/12/12 05:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You WILL have to grind in the timing chain area of the block for the cover to fit. Pretty straight forward install just get the grinder out. I have installed at least 7 of the things in a Mopar BB/Hemi and all needed a fair amount of clearancing for the cover to fit. Although the KB stuff needed the least work for good fitment.
Re: Jesel Belt Drive, Installation instructions? [Re: Al_Alguire] #1195776
03/12/12 07:13 PM
03/12/12 07:13 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Hi Tig, pm me your email address and i will send you my installation instructions. cheers rob.
Re: Jesel Belt Drive, Installation instructions? [Re: 572B1] #1195777
03/12/12 09:39 PM
03/12/12 09:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Watch out for the dots on the pulley. On mine they weren't even close. Put the cam at split overlap and you'll see what I mean. Mine was so far off you couldn't rotate the motor a complete revolution because the cam lobes hit the rods. Ended up moving it 3 teeth. From what I hear this is not uncommon.
Doug
Re: Jesel Belt Drive, Installation instructions? [Re: dvw] #1195778
03/12/12 09:56 PM
03/12/12 09:56 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
You might want to PM Mopar Rich,just sayin!
PM sent
Re: Jesel Belt Drive, Installation instructions? [Re: dvw] #1195779
03/13/12 12:27 AM
03/13/12 12:27 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
As DVW mentioned, not uncommon to get a jesel set up that has been stamped (dots) with big block chevy indexing... i had one and have heard of quite a few others have also (will be about 3 teeth off).
It will be apparant if mismarked when you index the cam in..... is not a big deal, unless you just line the dots up ..... and let her rip
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Jesel Belt Drive, Installation instructions? [Re: 572B1] #1195780
03/13/12 04:54 PM
03/13/12 04:54 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Cheers Rob
Thanks for all the tips fella's
Tig
Re: Jesel Belt Drive, Installation instructions? [Re: Tig] #1195781
03/13/12 06:02 PM
03/13/12 06:02 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Cheers Rob
Tig
PM sent
Re: Jesel Belt Drive, Installation instructions? [Re: 572B1] #1195782
03/15/12 10:27 AM
03/15/12 10:27 AM
SD
SG5438 Offline
SG5438  Offline
SD
Mine showed up with a SB chevy belt. So make sure you have the correct belt, 31010 is the PN.
2015 3500 Mega Cab Cummins
1970 Plymouth GTX - 7.99 @ 170 @ Bandimere
Re: Jesel Belt Drive, Installation instructions? [Re: SG5438] #1195783
03/15/12 04:12 PM
03/15/12 04:12 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Thanks. All good to go.
Re: Jesel Belt Drive, Installation instructions? [Re: SG5438] #1195784
03/15/12 07:12 PM
03/15/12 07:12 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Thanks for that Rick. Mine turned up with a big block chev thrust washer.
I emailed Jesel, and they posted the correct washer straight out.
I just checked the belt part number, and its a 31010.
Re: Jesel Belt Drive, Installation instructions? [Re: 572B1] #1195785
03/20/12 02:42 PM
03/20/12 02:42 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Just had a trial fit with the back plate. It appears not to need any clearancing at all
Where do you guys have to move material from normally
TIA
Tig.
Re: Jesel Belt Drive, Installation instructions? [Re: Tig] #1195786
03/20/12 05:03 PM
03/20/12 05:03 PM
Probally the boss around the stock fuel pump pushrod passage That is the area needing attention on the conventional full cover gear drives like the KB and Milidons
Re: Jesel Belt Drive, Installation instructions? [Re: Cab_Burge] #1195787
03/20/12 05:33 PM
03/20/12 05:33 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Ahh.... No Mech Fuel pump option on this block.
