Power Windows, what was I thinking! (update again!)
#1195586
03/12/12 09:34 AM
03/12/12 09:34 AM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
So I have been working on this 68 GTX that I picked up in the fall. Had the interior out of it, rebuilt the dash, etc.. Got it all back together this past week and crossed my fingers and fired it up. Everything worked! All the gages, switches, everything! This almost never happens!
The car has power windows. In my enthusiasm with how things were going, I cycled the windows. Big mistake, on the second time through the right rear window went down and now won't come back up. When the switch is toggled, there isn't even a drain on the ammeter. The other windows still work.
Damm...now I will have to rip out the back seat, etc. to get to the guts! Any tips or thoughts as I get started? I actually have a new NOS motor and new NOS single switch in my stash of parts. I did not rebuild anything associated with the windows prior to this
Re: Power Windows, what was I thinking!
[Re: Kowal]
#1195587
03/12/12 12:13 PM
03/12/12 12:13 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
pop the switch off and take a jumper wire to try and get that motor to spin the window up.
I've got a car with power windows and I never roll my rear windows down completely because the motor's are weak..this lets me grab the windows and help them up when necessary
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: 3_RTs]
#1195589
03/12/12 02:51 PM
03/12/12 02:51 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
If the motors were dragging due to stiff grease or binding or whatever you would register a load when cycling the switch.. No power it getting to the motor, it's a switch problem... The master & the single switch both can cause the window not to work from either switch... If you haven't touched the single chances are it's the master... If you have spare switches try swapping them out... And when your done messing around & just want the windows to work every time.. https://board.moparts.org/ubbthreads/show...e=0#Post4775992
[Re: 1_WILD_RT]
#1195590
03/12/12 09:22 PM
03/12/12 09:22 PM
Kowal
Charlotte, NC
Ok, latest...
I switched the single switch with a known good one...no change...no movement and no load on the ammeter. The other three windows work well.
I ran a volt meter across the switch. I am getting power to the single switch that shows when I toggle the switch with the meter on either the down or up wires and ground.
Now here I where I get confused. I tried to put a battery charger across the green up wire and ground. The charger tripped its safety circuit each time. On the gray down wire, nothing happened ( the window is down).
So I guess next is out comes the seat? In order to either jumper the motor or swap it? Remember this is the right rear. What a pain, nice new interior too!
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: buildanother]
#1195592
03/12/12 10:47 PM
03/12/12 10:47 PM
Kowal
Charlotte, NC
I believe the motor uses just the two wires that change polarity with each direction you want motor to operate.
Got it, I'll try again
[Re: buildanother]
#1195593
03/13/12 02:47 AM
03/13/12 02:47 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Thats correct, you just change the polarity of the wires going to the motor. It sounded like one may be shorting to ground?
The relay setup that I posted a few years ago, is a good idea as it takes the high current motor load off the switches.
[Re: 451Mopar]
#1195594
03/13/12 03:22 AM
03/13/12 03:22 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Actually by design both leads going to the motor are sent to ground through the master switch.... Either switch can break the ground to one wire & apply power to that lead... Adding relays means the ground path is shortened to inside the door... As well as making the power path more direct.....
[Re: 451Mopar]
#1195596
03/13/12 04:29 AM
03/13/12 04:29 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
He hasn't pulled the seat so he's working at the switch connector, I can't seem to find a schematic but going off memory on the cars I've done power window work green & gray don't go to the motor...
No reproduction parts... And if the harness were reproduced it's likely it wouldn't get improved upon with relays..
[Re: 1_WILD_RT]
#1195597
03/13/12 07:29 AM
03/13/12 07:29 AM
Kowal
Charlotte, NC
Using this, not a 68 but the colors still match
[Re: Kowal]
#1195598
03/13/12 12:02 PM
03/13/12 12:02 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
according to that the color to the motor & the color to the switch are the same so position is the only way to id the wires... just be sure your using the wires that are diagonal to each other & don't power up with the master switch... And when testing the connector for power remember both leads that will power up when the master switch is toggled need to receive ground when ever they don'e receive power.. I suspect thats where you'll find your problem & ground for all windows is always a function of the master switch..
[Re: 1_WILD_RT]
#1195599
03/13/12 02:09 PM
03/13/12 02:09 PM
Posts: 4,576 Sarcoxie, MO, USA
MoPar Jamie
Sarcoxie, MO, USA
I know from experience working with 80s Dodge trucks that even a bad motor will register some kind of load on the ammeter. Those truck ammeters almost never move so it is a pretty good load.
Sounds like something in the switch or the wiring. If the drivers master switch is messing up then you wont get any power to the switch in the back. learned that from experience as well.
- MoPar Jamie
1972 Fury III 4dr 1986 D-150 LWB Royal SE
[Re: MoPar Jamie]
#1195601
03/13/12 02:11 PM
03/13/12 02:11 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Actually you will have power on the center location... What you won't have is a ground....
[Re: 1_WILD_RT]
#1195602
03/16/12 08:05 PM
03/16/12 08:05 PM
Kowal
Charlotte, NC
Got the window back up! Used a battery charger and jumpered the window at the rear switch and it came right up, nice and strong. Guess that it's not the motor, which is good news. New switch on the back window and it still doesn't go up on its own. So next will be to try a new front four gang switch I guess. The other windows all still work.
