Exhaust stud removal #1194422
03/10/12 02:23 PM
03/10/12 02:23 PM
Westphalia, Meeeeeshigan
MIRADAMANia Offline OP
The exhaust studs on my 440 are cut too short for the flanges of the Hooker headers I'm installing. What's the best way to remove them without breaking any?
Re: Exhaust stud removal [Re: MIRADAMANia] #1194423
03/10/12 03:19 PM
03/10/12 03:19 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Heat is your friend here. Double nut them, heat the casting with a torch, try to move them in a shiver before backing them out. Good luck.
Sheldon
Re: Exhaust stud removal [Re: RUNCHARGER] #1194424
03/12/12 01:16 PM
03/12/12 01:16 PM
Thanks! Its funny, I talked to a guy at Muscle Motors and he said do not use heat. I thought heat would be the way to go, too. Any body else have good luck getting these out?
Re: Exhaust stud removal [Re: MIRADAMANia] #1194425
03/12/12 01:24 PM
03/12/12 01:24 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Had a full set of those to remove.Bought a stud removal tool.It is a eccentric cam deal with a 3/8 or 1/2 drive square for a ratchet, grabs the stud very tightly when you turn it.No set up.
For me, anyway, sometimes the double nut slips.
With this tool, you heat up around the stud (within reason) and grab with tool and turn.Soon as you apply pressure, there is an audible click and out she comes.
Re: Exhaust stud removal [Re: Sixgun] #1194426
03/12/12 02:14 PM
03/12/12 02:14 PM
Bowling Green KY / Nashville, ...
300by500 Online content
300by500  Online Content
When one breaks off, it is usually better, quicker, and easier to remove the head, then extract the broken stud. It can be difficult to get the correct angle on the removal / re-threading tools with it still installed.
Ooops! Did I say "when"? I meant to say "If".
Re: Exhaust stud removal [Re: MIRADAMANia] #1194427
03/12/12 02:57 PM
03/12/12 02:57 PM
PA
BTTG Offline
BTTG  Offline
PA
1/3 of mine I was able to remove with the help of a propane torch/wax/various penetrants....
1/3 I broke off with above efforts.....
final 1/3 as well as extracting the broken studs were removed by my machine shop for $10...
Re: Exhaust stud removal [Re: BTTG] #1194428
03/12/12 03:01 PM
03/12/12 03:01 PM
Sounds familiar. I had a '69 Chrysler 300 2-door, broke a stud and spent a frustrating 5-6 hours trying to get it out. Then I realized it would've been faster to just remove the head - had the head off in 45 minutes and the machine shop fixed it (and a messed up spark-plug thread) for $20.
Re: Exhaust stud removal [Re: 300by500] #1194429
03/12/12 04:01 PM
03/12/12 04:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Here's what I use.
Haven't broke one this way.
No trips to the machinists for me.
I have mechanical Aptitude.
I can screw up anything.
Re: Exhaust stud removal [Re: MIRADAMANia] #1194430
03/12/12 04:33 PM
03/12/12 04:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Here's the proper tool to install and remove. It's way better than the cam tools and won't damage the stud.
I still would use a little heat if it didn't want to come out cold.
The cam lock tools in the rear are not nearly as effective as the collet stud tool.
Re: Exhaust stud removal [Re: bboogieart] #1194431
03/12/12 04:33 PM
03/12/12 04:33 PM
Here's what I use.
X2. Though I try to use the hot wrench and hammers as little as possible there is one app that I use the torch almost every time & that is on every ex stud. I'm wondering why the other place advised against it. If it wont come out w double nutting it w a reasonable amt of torque then I fire it up
Re: Exhaust stud removal [Re: RapidRobert] #1194432
03/12/12 04:36 PM
03/12/12 04:36 PM
Cincinnati, Ohio
Cincinnati, Ohio
When you build engines that every fastner is a stud, you need the right tools.
Re: Exhaust stud removal [Re: RapidRobert] #1194433
03/12/12 04:37 PM
03/12/12 04:37 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Here's what I use.
Yeah, really. I mean, how hot does the head/exhaust get anyway? Pretty hot!
Re: Exhaust stud removal [Re: bobs66440] #1194434
03/12/12 06:55 PM
03/12/12 06:55 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here's the tricks my machine shop friend taught me. He works on many vintage 30s & 40s engines. First you heat the stud not the head. Then quench the stud with a spray bottle. Try to remove it gently. If it's still stuck repeat. Still stuck? Reheat and melt a candle into the threads, cool and try again. I would also recommend the Craftsman stripped nut remover set. It's about $25 and grabs about anything. I've had this method work nearly every time,and I've done quite a few.
Good Luck
Doug
