360 compression #1194192
03/09/12 09:13 PM
03/09/12 09:13 PM
minnesota
P
president61 Offline OP
P
minnesota
I have a stock 1978 360. since It is very low miles I just want to re-ring it and use the stock dished pistons. Between decking the block and milling the J-heads, can I achieve a 9:1 compression ratio? thanks
Re: 360 compression [Re: president61] #1194193
03/09/12 10:11 PM
03/09/12 10:11 PM
buffalo, new york
0
00snake530 Offline
00snake530  Offline
buffalo, new york
I would cc the heads to see exactly what compression ratio you have now, a rule of thumb is you have to mill off .0048 inches to take 1 cc of combustion chamber volume out of the heads (-3cc's should yield ruffly a .2 increase in compression) and a ruff figure on the deck is every .010 milled off or (.010 less in the head gasket) will yeild .15 compression increase
70 Challenger r/t 4 speed
00 Viper gts
67 satellite pro street
03 Ferrari 360 spider
50 chevy fleetline deluxe
15 Escalade (daily)
Re: 360 compression [Re: 00snake530] #1194194
03/09/12 10:19 PM
03/09/12 10:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
