Hotchkis b-body swaybar #1193763
03/08/12 11:52 PM
03/08/12 11:52 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
I just got a hotchikis front sway bar for my 69 charger and am having difficulty fitting it in. The car had a swaybar stock so I'm just using the old endlink mount. But it seems like the bar ain't long (rubs my strut mounts) enough even though holes of my old bar line up with this one. WTF. Help?
Re: Hotchkis b-body swaybar [Re: paulyvault] #1193764
03/09/12 12:01 AM
03/09/12 12:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Did you think to lay the stock bar atop the new one to verify that the contours are similar?
Re: Hotchkis b-body swaybar [Re: Kern Dog] #1193765
03/09/12 12:11 AM
03/09/12 12:11 AM
ca, slo.
P
P
ca, slo.
Did that. More or less
Re: Hotchkis b-body swaybar [Re: paulyvault] #1193766
03/09/12 02:03 AM
03/09/12 02:03 AM
ca, slo.
P
P
ca, slo.
Yo
Re: Hotchkis b-body swaybar [Re: paulyvault] #1193767
03/09/12 01:44 PM
03/09/12 01:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So, the distance from the endlink holes to endlink holes are the same?
If the enlinks were taller or shorter would that stop the rubbing with the strut rod?
Re: Hotchkis b-body swaybar [Re: autoxcuda] #1193768
05/28/12 05:30 AM
05/28/12 05:30 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Hmmm... THIS went nowhere.
Re: Hotchkis b-body swaybar [Re: Kern Dog] #1193769
05/28/12 11:06 AM
05/28/12 11:06 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Hopefully he figured it out.
Re: Hotchkis b-body swaybar [Re: Dan@Hotchkis] #1193770
05/28/12 02:23 PM
05/28/12 02:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think that last question may have held the answer.
- Stu Harmon
Re: Hotchkis b-body swaybar [Re: feets] #1193771
05/28/12 10:48 PM
05/28/12 10:48 PM
IN
ahy Offline
ahy  Offline
IN
On my rear bar, I had to lengthen the end links with a small stack of 1/8" thick shim washers to position the bar to clear the rear diff and exhaust. Depending on your exact ride height, some adjustment may be required.
Re: Hotchkis b-body swaybar [Re: ahy] #1193772
05/29/12 01:13 AM
05/29/12 01:13 AM
Whose rear bar do you have installed?
