Alternative to the mallory replacement fuel filter #1193683
03/08/12 10:03 PM
03/08/12 10:03 PM
Overpriced Housing Central
RobX4406 Offline OP
RobX4406  Offline OP
Have a 3140 mallory fuel filter. It uses an open element filter that is 2.75" tall, 2.75" dia and has metal plated ends w/ 1" centered holes
Anybody know of a 40 micron replacement filtere for these. The mallory ones are STUPID expensive for a basic style paper element, $30.
This is the filter.
TIA
Re: Alternative to the mallory replacement fuel filter [Re: RobX4406] #1193684
03/09/12 09:20 AM
03/09/12 09:20 AM
tboomer Offline
tboomer  Offline
Not much help,Rob...But they have them on Amazon for 25.00. When I had a Fram canister,I was using filters from a company called Big End.
Re: Alternative to the mallory replacement fuel filter [Re: tboomer] #1193685
03/09/12 03:36 PM
03/09/12 03:36 PM
RobX4406 Offline OP
RobX4406  Offline OP
Thanks Ted.
I have a bunch of the Fram HPGC elements and they are different. Those are about $6. I did find a place with the Mallory elements for about $15 delivered. Lots less than the big houses.
Re: Alternative to the mallory replacement fuel filter [Re: RobX4406] #1193686
03/09/12 05:26 PM
03/09/12 05:26 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
buy the metal screen type for the mallory EFI filter and you wont have to buy any more paper filters
Re: Alternative to the mallory replacement fuel filter [Re: sixpackgut] #1193687
03/09/12 10:51 PM
03/09/12 10:51 PM
RobX4406 Offline OP
RobX4406  Offline OP
Do you have a part number. I've only found the paper elements.
Re: Alternative to the mallory replacement fuel filter [Re: RobX4406] #1193688
03/09/12 11:18 PM
03/09/12 11:18 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
edit: oops, not it. IDK. mine is wire mesh material.
