Re: Lookin at a 340, I'll need an elec vac pump PBrakes?
[Re: cudabitten]
#1193331
03/08/12 05:42 PM
03/08/12 05:42 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
been running run for about 5 years on my Satellite,only pulls 4-5" at idle.Had to rebrush the pump motor once.I had a pressure switch to cycle it on and off,though i now just run it all the time as the pressure switch crapped out.no worries on my daily driver
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
