Vinyl Dye / Paint help please / questions - Blue inter
#1193178
03/07/12 11:11 PM
03/07/12 11:11 PM
Posts: 132 Olive Branch, MS (suburb of Me...
billboardlover
I am about to do an interior of a 71 Cuda. I have never used vinyl dye and wondered if some of you thst have could give me some tips and recommendations. I seem to keep seeing SEM as the brand of choice. Also, what do you all think of the panels I have at present. Will they really clean up and look close to new after being dyed, even the hard plastic parts. Does the dye really penetrate these? Are they too rough? I just hate to spend the $ on new ones. Thanks for your help.
Re: Vinyl Dye / Paint help please / questions - Blue inter
[Re: fireeng]
#1193183
03/08/12 09:51 AM
03/08/12 09:51 AM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
I redid some blue plastic in a gTx. A local NAPA mixed the paint/dye because SEM had nothing close. They were the darker blue so you might be able to match yours in a can. I bought a quart and used a spray gun. It turned out good, with no signs that the part had been "painted". My plastic was all in good shape with no deterioration to begin with.
Everybody makes fun of a hillbilly until they need something fixed
[Re: 70plymA34]
#1193186
03/08/12 09:45 PM
03/08/12 09:45 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
not to knock SEM but DuPont Vinyl Dye is the best out there. a little expensive and you have to use a gun to apply it. just get the color code for that blue and any dupont jobber should be able to mix it in your choice of gloss, satin or flat. however the key to a pro job is the laborous cleaning and prep work under the dyed panel. good luck IMHO the satin finish is closest to OEM.
.........Yes I also like the dupont stuff in satin. Try to use the best used blue panels you can for this and a good prep is a must. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: THESHAKERPROJECT]
#1193187
03/08/12 11:49 PM
03/08/12 11:49 PM
Prep is king!
I used Dupli-color on some of my blue panels to turn them red.
I thoroughly washed them down with soap and water on BOTH sides to get all the dirt off. I then used wax and grease remover and finally a good adhesion promotor.
I tried my best to scratch the stuff off in an inconspicuous place and couldn't do it!
#1193188
03/09/12 10:14 AM
03/09/12 10:14 AM
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Yeah anytime you paint/dye something you have to prep it well to get good results. I used DuPont Pla-Stick on my plastic parts before spraying, and always wore surgical gloves to keep things clean.
[Re: B_Body_Bob]
#1193191
03/10/12 08:36 PM
03/10/12 08:36 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I used a rattle can from Year One for this console and I could not be more pleased..It looks absolutely perfect...It had faded into a teal grean color and it was horrible...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: 72N96RR]
#1193192
03/11/12 02:41 PM
03/11/12 02:41 PM
Posts: 373 Kings Beach, CA
tahoechallenge
Kings Beach, CA
What color did you use? They have several blues listed.
[Re: tahoechallenge]
#1193193
03/12/12 02:48 PM
03/12/12 02:48 PM
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
number 340....costs about 16 bucks a can..
[Re: ThermoQuad]
#1193197
03/15/12 10:42 PM
03/15/12 10:42 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I've used all sorts of vinyl dye. I prefer the Dupont and PPG dye sprayed through a gun but I have also used the SEM, Dupli-Color, and Plastic-Kote brands in an aerosol can and have been pleased with them too. Mo-Paints also makes a good aerosol spray that matches nicely. The higher priced stuff seems to last longer than the cheaper Plasti-Kote and Dupli-Color stuff. But... as mentioned already numerous times..... PREP work is the most important thing before you do anything. Another thing that is equally as important as the prep work is the application method. When spraying it... with a gun or a can.... apply with MANY light coats. Do not flood it on in one or two coats. Applying very light coats will give the dye a chance to soak into whatever it is being applied to.
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
