Re: Ritter XR Aluminum Block Pics
[Re: fishy340]
#1193110
03/08/12 11:33 AM
03/08/12 11:33 AM
dartman366
Mt. Vernon, Ohio
bigcube i believe u can go p7,w7,w8,w9 or even 59deg stuff with that block + over 450ci no prob that will be my next block for sure
this sure has my interest.
[Re: AndyF]
#1193114
03/08/12 12:32 PM
03/08/12 12:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Yes, can you imagine what that does to the " entering" cornering, and less of a weight shift /nose drop upon deceleration? I hope this block is what it appears to be, a long overdue piece to help the Mopar crowd compete a little better with the Gms.
RIP Monte Smith
[Re: fishy340]
#1193115
03/08/12 03:36 PM
03/08/12 03:36 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
P5?
[Re: 408strokerdart]
#1193118
03/09/12 12:15 AM
03/09/12 12:15 AM
Posts: 2,864 IN
Irun5snd8th
IN
Man, I cant even imagine what it would be like to drive my car with an aluminum block up front That would put ol Bob's front end to the test!
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
#1193119
03/09/12 07:34 AM
03/09/12 07:34 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
What size cam tunnel? Are there drains in the lifter valley? I don't see them. I agree that this is a long needed item.
Brian, the cam tunnel is isolated from the rotating assembly with return drain located at the rear of the block. Cam bearing bulkheads are drilled front to rear to allow oil to flow rearward.
Cam tunnel machining preference is optional, I know at least up to 60mm.
[Re: S/ST 3040]
#1193120
03/09/12 10:11 AM
03/09/12 10:11 AM
Posts: 3,456 Out West
408strokerdart
Out West
Ok. Thanks for the info.
#1193121
03/12/12 05:49 PM
03/12/12 05:49 PM
Posts: 210 mass,usa
sickhemi
mass,usa
hello does anyone know when these beauty's will be ready to ship?
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
