Re: 340 Challenger not charging
[Re: RustyCarHunter]
#1192932
03/07/12 06:09 PM
03/07/12 06:09 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
If that brown wire is long, then it might be your carb solenoid or electric choke wire.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Andrewh]
#1192935
03/07/12 06:54 PM
03/07/12 06:54 PM
Posts: 82 Acworth, GA
RustyCarHunter
Acworth, GA
The think black wire reads 0 when the car is turned off. Then reads betteen 13 and 14 when the engine is running.
one of the leads says -0.02 and the other reads .04 when the engine is running
[Re: Andrewh]
#1192937
03/07/12 10:10 PM
03/07/12 10:10 PM
RapidRobert
The blue and the green would go on the (2) alt 1/4" male field terminals. The large black wire goes on the large "batt" alt stud. The black wire must show near batt voltage at all times if it's continuity is kosher & if not there's a prob. The brown wire does not go to the alt but to a nearby sending unit or similar component.
[Re: MyPlum1970E]
#1192942
03/09/12 04:02 AM
03/09/12 04:02 AM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
I know that the OE wire coming off the harness by the firewall that runs to the Thermoquad manifold choke is green on a '73.
