parts are starting to trickle in for this transmission have just about everything at this point, was mocking up some stuff tonight. at this point i shelved the roller idea (might do another one with it) so i'm putting all new thrust washers in it. i got a pack of the sonnax planetary shims figuring i might need them and i did. the instructions say to install them under the thrust washer on the front of the rear planet. to get the end play where i want it it's needing three .010" shims. i'd rather not put them all under that washer and see no reason i can't put one under the washer on the rear of the front planet. with the three shims and a .058" selective snap ring i'm ending up with about .007" end play.
any thoughts on the shim location? don't want to put all three under one washer
