cc milling #1192193
03/06/12 11:21 AM
03/06/12 11:21 AM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
hello,
any formula for milling heads to reduce chamber cc's, 78 cc's now would like to go to 70, after 6 years putting togeather 540 (stage IV 285 chapmans)
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: cc milling [Re: 440lebaron] #1192194
03/06/12 11:46 AM
03/06/12 11:46 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i don't know what the amount is for that head but there is a way to determine depth of cut if you have the tools.
you need to level the head side to side and end to end precisely (machinist not a carpenters level). have both valves installed and sealed, spark plug, then with a accurate burette fill the chamber with the desired volume of fluid. take a depth micrometer set it on the deck surface and turn the spindle down until it's close to the surface of the liquid. then slowly turn it until the liquid jumps up onto the spindle of the mic, take your reading and that is the amount needed to cut.
Re: cc milling [Re: 440lebaron] #1192195
03/06/12 05:50 PM
03/06/12 05:50 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Yeah, it's got a smallblock.
