Re: Blower motor build?
[Re: griff70440]
#1191846
03/06/12 07:48 PM
03/06/12 07:48 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
race only.not sure on the type of alcohol.Looking to make 2000-2500hp give me your advice..
thanks
oh so you want blown572dart's engine. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: griff70440]
#1191848
03/06/12 09:13 PM
03/06/12 09:13 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Some questions:
1) What type of racing are you going to do?
2) What transmission are you going to run?
3) What experience do you have with a blown alky motor?
4) How many passes do you need the motor to last?
5) What is telling you of your required HP goals of 2000-2500HP?
6) Do you have a crew member to maintain the engine in between and at the races?
7) What type of budget are you planning on for MOTOR only? Not including all the incedentals etc.
RIP Monte Smith
[Re: Defbob]
#1191852
03/06/12 11:46 PM
03/06/12 11:46 PM
Posts: 169 SW WI
cudacustoms1
SW WI
Buy a used complete motor and request the seller to give you some tuning and maintenance advice/tips.
you can pick an older ready to run ex-top alcohol motor for $10K-15K.
Just be carefull what you buy. I been down that road. Bought a "ready to run long block" with cracks in the pistons and block. The titanium valves,oil pump and cam was junk.The crank was twisted. You get the picture.If you do buy used have a third party check the motor/ parts out before you buy.There are some good deals.Another thing to think about is do you want to go with fuel or fatheads. The parts don't interchange.If your looking to go as fast as you can on a buget you can go fast for a fairly cheap. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: griff70440]
#1191853
03/07/12 01:07 AM
03/07/12 01:07 AM
Posts: 43,309 Bend,OR USA
Cab_Burge
Make the motor C.I. as big as possible, if your absolutely set on running a 14:71 then buy a high helix max boost unit, don't scrimp and buy a BDS or similar cheap blower ![](/ubbthreads/images/graemlins/tsk.gif) The screw blowers are better, I would go with one if I had the choice ![](/ubbthreads/images/graemlins/Twocents.gif) Buy the best flowing heads and the best crankshaft, aluminum rods, pistons and tool steel thick wall wristpins and the best valve gear you can get ![](/ubbthreads/images/graemlins/Twocents.gif) That power level is doable, but not cheaply ![](/ubbthreads/images/graemlins/tsk.gif) Let us know how it goes ![](/ubbthreads/images/graemlins/thumbs.gif) BTW, I'm availble for consulting by the hour, not real cheap though ![](/ubbthreads/images/graemlins/scope.gif) PM me if interested ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Cab_Burge]
#1191854
03/07/12 01:49 AM
03/07/12 01:49 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Make the motor C.I. as big as possible, if your absolutely set on running a 14:71 then buy a high helix max boost unit, don't scrimp and buy a BDS or similar cheap blower The screw blowers are better, I would go with one if I had the choice Buy the best flowing heads and the best crankshaft, aluminum rods, pistons and tool steel thick wall wristpins and the best valve gear you can get That power level is doable, but not cheaply Let us know how it goes BTW, I'm availble for consulting by the hour, not real cheap though PM me if interested
Does that mean your cheap,not just REAL cheap?? ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: hemi-itis]
#1191855
03/07/12 10:28 AM
03/07/12 10:28 AM
CompWedgeEngines
Syracuse,NY
You do NOT want big cubic inches with a blown alky motor. That is not a good approach. You will notice almost all serious effort professional level motors of this type are 490-520 cubic inches. There is a reason for that. ![](/ubbthreads/images/graemlins/whistling.gif)
RIP Monte Smith
[Re: Challenger 1]
#1191859
03/07/12 11:20 PM
03/07/12 11:20 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
If you do this, listen to only one person and nobody on this board.
Best advice you've gotten so far
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Challenger 1]
#1191860
03/08/12 12:36 AM
03/08/12 12:36 AM
CompWedgeEngines
Syracuse,NY
Gary, I " think" I know what you mean....sorta.... ![](/ubbthreads/images/graemlins/laugh2.gif) I was giving him advice based on experience, not mumbo jumbo or sideline quarterbacks....we have a 451 combo also that runs well...good combos. Dynoed the blower over the winter and Bob spent some time at Rage this Winter....all new...so hopefully it doesnt give us too much grief re-tuning it....I dont think so though. We were at the limits of the pump.
RIP Monte Smith
[Re: CompWedgeEngines]
#1191861
03/08/12 01:07 AM
03/08/12 01:07 AM
Posts: 12,295 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You might what to check the classifieds on here.
Master, again and still
