Rear Spring set-up #1191438
03/05/12 01:34 AM
03/05/12 01:34 AM
Detroit, Michigan
sbsatellite Offline OP
Detroit, Michigan
I am moving the springs in-board on my 71 Satellite, I have the front boxes welded in and am working on the rear. Should the rear mount be put in the frame using a hole saw or welded to the bottom of the frame and use gussets. Both ways are in the instructions from Mopar.
Any pics of this would be great!!
Thanks again!
Re: Rear Spring set-up [Re: sbsatellite] #1191439
03/05/12 09:45 PM
03/05/12 09:45 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Not sure with the 71-B,, but ideally go with the hole in the frame rail route. The issue can be that the frame rail doesn't run parallel to the car....
Re: Rear Spring set-up [Re: sbsatellite] #1191440
03/05/12 10:54 PM
03/05/12 10:54 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Why not put some spring sliders on instead. These work great.
