Re: need info on a 302/308 head
[Re: imfixinmopars426]
#1191337
03/05/12 12:24 AM
03/05/12 12:24 AM
Posts: 15,487 Florida
scratchnfotraction
#302 head is a small valve/port head with a closed chamber 1.78/1.50
#308 is a 360 big port/valve head with open chamber,the exhast port on a #308 is better and the best head to use,1.88/1.60..they are known for cracking and they are hard to find also.
#302 heads would kill a 408 IMHO,unless they were max ported with bigger valves and would still hold it back.
#302 heads with 1.88/1.60 valves and a max port job will be good for around a 450 HP engine.
the bigger valves will increase flow and keep the port volocity up along with a comp ratio bump with the closed chambers.
I could be mistaken on the CC measurement but it is close IIRC
IMHO a 360 head/X heads with 1.88/1.60 or 2.02/1.60 valve size would be the better heads
#1191338
03/05/12 12:38 AM
03/05/12 12:38 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
302 is a great head for a SB, its closed chambered head around 62CC's but has a intake shape that has a hard turn in it for the larger pushrod holes. I believe a stockish 318 head is about 65CC. 308 head is the 360 head, open chambered. I would use the 308 opened to 2.02 for the stroker though. Great exhaust post.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
#1191339
03/05/12 12:53 AM
03/05/12 12:53 AM
Posts: 600 Spartanburg SC
MoparDan
Spartanburg SC
several yrs ago, I was on a hunt for a set of 308 heads for my 416, the two set I found (salvage yard off the motor) were both cracked....then I took a set off a wrecked 92 truck (two three hours) took to machine shop only to find they were cracked Finally I then took an old set of J heads I had laying around the shop put in ss 2.02 1.60 purchased a MP porting template kit and I'm prally pleased with the performance If you really want new....I would recommend the Hughes LA-X iron heads: 'heart' shaped chamber, larger port size, 1.92 - 1.60 and for about $1100 you will have a great set of heads... ![](/ubbthreads/images/graemlins/Twocents.gif)
#1191340
03/05/12 01:02 AM
03/05/12 01:02 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
If you don't already have a head then you should look at magnums, they make more HP, TQ and MPG than ANY of the older ones either stock VS stock or ported VS ported. They have a better chamber, better ports, lighter valves, higher rocker ratio, better valve cover sealing... they do almost all have cracks but they don't ever seem to have any issues from the cracks.
If you are bound and determined to use the older heads you have to make compromises, X heads flow best by a tiny bit but no hard seats, 302 is closed chamber but flow sucks, 308 has good quality flow but very sucky chambers, really though all the big port 360, 340, 318 4bbl heads have horrible chambers. If I could pick any LA head for a street stroker it would probably be (reluctantly)a 308.
[Re: dogdays]
#1191342
03/05/12 08:52 PM
03/05/12 08:52 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I ran a set of stock 87 302 castings on a mild 79 360. Simply because I had them and the stock 79 heads tore out an exhaust stud that had already been repaired.
In an 87 Diplomat I lost about 15-20 mph top end (115 vs estimated 130'ish on the cop speedo)compared to the stock 79 heads and a set of J heads I tossed on it later. However, I gained lot's of low end torque and with an Edelbrock 1406 carb I would get low - mid 20's for mpg.
I would not use them for anything hotter than a mild 360 myself and only if I had a set lying about. If I had to buy a set of heads I would start with Magnums at the least.
[Re: MoparDan]
#1191344
03/05/12 11:08 PM
03/05/12 11:08 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
i thought the 302+308 had the same ports,and size,so i bought a fresh set from my engine builder for 300.00,thinking they might be a good torque head for the 408,but now im thinking i might use something else,and use the 302's on a low comp 360....thanks guys,i might call hughes
[Re: RUNCHARGER]
#1191345
03/05/12 11:11 PM
03/05/12 11:11 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I suppose to get 11.5, the DC pistons are domed above deck? What's your plan to work that with closed chamber heads?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: RUNCHARGER]
#1191347
03/16/12 08:14 PM
03/16/12 08:14 PM
pishta
Tustin, CA
We're building an interesting 360 for my kid's 360. It is a rock crawler so it needs to run at an angle and have lots of response. I found some rare DC, forged 11.5-1 pistons on Moparts for it and we are going to try the 302 heads we have on it and run it on propane. I am expecting it to be very responsive on the low end and able to run properly at an extreme angle. We haven't chosen a camshaft yet but I'm sure it will be all done by about 4500 RPM.
Sheldon
Need an SP2P? If your going for grunt, you cant beat that intake...
[Re: scratchnfotraction]
#1191350
03/17/12 04:02 PM
03/17/12 04:02 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
If I may, our 366 in our 74 RR dynoed a 503hp. With a fully hogged out set of 302's w/ 2.05/1.60 valves. I never expected the heads to last. Its coming up on 10 years now w/o any major problems other then a blown head gasket.
As always, results my vary ![](/ubbthreads/images/graemlins/grin.gif)
[Re: HotRodDave]
#1191352
03/17/12 07:29 PM
03/17/12 07:29 PM
DARTH V8Я
Its a TRAP!
Thats why I said, 'your results may vary' Dyno sheets? ha! long gone! But I'm sure they fudged the numbers ALOT. Seat of the pants maybe 420ish.. Its always been an upper-mid 11 second car (4-speed/3.91's). life isn't always about flow#'s ![](/ubbthreads/images/graemlins/thumbs.gif) I should add, never hit water with the porting, but did break through the pushrod wall. Sleeves w/brazing took care of that. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: DARTH V8Я]
#1191353
03/18/12 01:09 AM
03/18/12 01:09 AM
Posts: 4,323 NY NY
340duster340
NY NY
What do you use to plug the smog pump holes on the heads under the exhaust ports.?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
#1191355
03/18/12 02:04 PM
03/18/12 02:04 PM
imfixinmopars426
michigan woods
called brian at IMM engines,bought a set of RHS heads prepped by brian....done! also got stroker kit,cam/lifters,and tons of good advice...call them!...mike
