Page 1 of 4 1 2 3 4
400 BB Mopar budget dyno test***MORE PICS #1190574
03/03/12 10:53 PM
03/03/12 10:53 PM
SoCal
Brian Hafliger Offline OP
SoCal
Just finished doing a 2 part build using a 400BB Mopar.
We took a steel 383 crank, stock rods, KB flat top pistons and filled the stock 400 block. First test was with 906 heads, milled .050 for 79cc and compression was 9.8:1 and zero decked.
We chose a thumpr hyd. cam, stock rockers, bowl cleanup in the ports, stock valve sizes (manley valves)and comp single springs.
Topped with an rpm intake, 1" open spacer and a box stock 750holley it made 427HP @ 5700rpm and 443Tq @ 4200rpm using TTI 1 7/8 headers. Here's a pic....
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190575
03/03/12 10:55 PM
03/03/12 10:55 PM
SoCal
SoCal
Heads:
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190576
03/03/12 10:56 PM
03/03/12 10:56 PM
SoCal
SoCal
bowl cleanup
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190577
03/03/12 10:59 PM
03/03/12 10:59 PM
SoCal
SoCal
I'll post more pics of the complete engine and dyno sheet monday.
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190578
03/03/12 11:08 PM
03/03/12 11:08 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190579
03/04/12 01:20 AM
03/04/12 01:20 AM
Brian, any bigger carbs on the tests coming
Re: 400 BB Mopar budget dyno test [Re: Cab_Burge] #1190580
03/04/12 02:43 AM
03/04/12 02:43 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Do you have a smaller set of headers to try Brian?
Re: 400 BB Mopar budget dyno test [Re: Cab_Burge] #1190581
03/04/12 02:44 AM
03/04/12 02:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We have a stock stoke .030 over 400 in my boys Dart with the 383 crank. It has KB pistons and with Eddy RPM heads that we cut it has 10.6 comp. Has the MP .557 cam and a 750 DP. Never dyno'd it but in his 3550 lb Dart it has run 11.40's @ 117. Its pump gas drive anywhere street car. Thats real nice looking 400 you have there. Do you plan to try and dyno the 400 with any other combo's in it ? Ron
Re: 400 BB Mopar budget dyno test [Re: 383man] #1190582
03/04/12 02:59 AM
03/04/12 02:59 AM
SoCal
SoCal
I think the potential for much more power is there and I can say we did try a different topend package/camshaft and had good results.
I can't post that info yet...sorry.
Given the Thumpr cam has kinda low lift, especially using stock rockers I was surprised.
It sounded awesome with both setups and never missed a beat. Super simple combo that made great power everywhere. When I post the dyno sheets you'll see what I mean...very W I D E powerband.
Brian Hafliger
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190583
03/04/12 10:05 AM
03/04/12 10:05 AM
tboomer Offline
tboomer  Offline
Brian....I remember you saying that you were going to try a set of standard port Victors on a moder....Is this the one?
Re: 400 BB Mopar budget dyno test [Re: 383man] #1190584
03/04/12 11:58 AM
03/04/12 11:58 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Ron I never had any luck with 557 cam. simple upgrade to 590. BIG difference!
If yoour son wants to go faster, that will be easy/cheap fix.
Don
Re: 400 BB Mopar budget dyno test [Re: cudadon] #1190585
03/04/12 12:57 PM
03/04/12 12:57 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
What is going on with the guides in those 906 heads?
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190586
03/04/12 01:15 PM
03/04/12 01:15 PM
NC
440Jim Offline
440Jim  Offline
NC
Nice to hear about a true low budget, mild build for the everyday hobbiest.
I am sure a set of Edelbrock RPM or similar heads would make a bunch more power, but at an added price. That cam sounds pretty small/mild also, but not everyone wants to trade off manners below 3000 rpm for the power above that.
And instead of that 383 (3.38" stroke) crank, a 3.75" crank would add 451/406=1.11 more pull. Again, at an added cost ~$100 (regrind) to $700 (new crank).
Re: 400 BB Mopar budget dyno test [Re: scatpacktom] #1190587
03/04/12 01:18 PM
03/04/12 01:18 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Dom,
That 590 cam might be just big enough to be a torque killer on Ron's son's 406. With his combo and weight the 557 seems to be to be just about right and it works very well for what is essentially a solid running and reliablly consistent package. 383-400's are more cam sensitive than any other motors in our stable due to that long rod short stroke. If I were to do anything on a 406 like that I'd run the longer 6.76 LY rod to get the piston weight down and lighten up the bob...that would work the heads even harder up top with no real downside.
WIZE
In Car:
Re: 400 BB Mopar budget dyno test [Re: scatpacktom] #1190588
03/04/12 01:47 PM
03/04/12 01:47 PM
SoCal
SoCal
Not sure what you mean?
Brian Hafliger
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190589
03/04/12 02:21 PM
03/04/12 02:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
It looks like there is a lot of FUZZ on the guides in the pictures you took ?
Re: 400 BB Mopar budget dyno test [Re: JohnRR] #1190590
03/04/12 04:52 PM
03/04/12 04:52 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Nice build. My street 383 is similar and I had always figured it made around that #.
Mine was close to tickling a 12 in a 4000lb package without a real fancy convertor. I'm sure with a 4800 stall it would have done it.
Now we need to see it run with some good stuff!
Re: 400 BB Mopar budget dyno test [Re: RemCharger] #1190591
03/04/12 05:20 PM
03/04/12 05:20 PM
USA
hudsonhornet7x Offline
USA
I have a question about the cam choice. I see a thumpr cam was used. Are they really a good choice with a wide powerband? When I look them up many people say they are junk, so it would be nice to hear the opposite in this case.
Re: 400 BB Mopar budget dyno test [Re: hudsonhornet7x] #1190592
03/04/12 06:19 PM
03/04/12 06:19 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I think the thumper is ground to sound more nasty than it really is? Similar to the Hughes Whiplash.
What pistons are you using? You using the B or RB rods?
383, Hemi 4-Speed, AlterKtion, D60
Re: 400 BB Mopar budget dyno test [Re: Brian Hafliger] #1190593
03/04/12 06:24 PM
03/04/12 06:24 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What are the specs on the Thumpr cam and is it a tall fill or short fill? What kind of water and oil temps were you seeing with the fill? Also, how much of a recess is left in the chambers in the quench area after milling the heads .050? Where you able to get any kind of half decent quench clearences? Or will I have to wait for the magazine article to find out?
Page 1 of 4 1 2 3 4
