71 barracuda steering wheel ribbed "can" removal #1190522
03/03/12 09:22 PM
03/03/12 09:22 PM
GA
roadrunninMark Offline OP
GA
I am trying to replace the turn signal switch as it doesn't stay in position when the stalk is pushed. I have the wheel off and I am at the can. I have a puller but the bolts are not long enough to extend past the ribbed "can". I need to buy some all thread to make the extended "bolts" to reach in and screw in to give the puller the needed leverage. I can't figure out what thread pitch/size/ etc. I need to thread into those two holes. Does anyone know the size/thread count/ (fine or standard) which those holes are? I don't want to pry against the can as it is pretty thin.
Thanks,
Mark
Re: 71 barracuda steering wheel ribbed "can" removal [Re: roadrunninMark] #1190523
03/03/12 09:25 PM
03/03/12 09:25 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Same bolts you have only longer.
Re: 71 barracuda steering wheel ribbed "can" removal [Re: Ron69rr] #1190524
03/03/12 09:29 PM
03/03/12 09:29 PM
GA
GA
I have two types of bolts with my puller, a fine thread and standard thread but neither are threading into the holes. I dont know if the threads were buggered or what, but I dont want to buy both all threads.
Re: 71 barracuda steering wheel ribbed "can" removal [Re: roadrunninMark] #1190525
03/03/12 09:48 PM
03/03/12 09:48 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
3/8" course
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 barracuda steering wheel ribbed "can" removal [Re: moparmarks] #1190526
03/03/12 09:52 PM
03/03/12 09:52 PM
GA
GA
thanks, that's what i need to know
Re: 71 barracuda steering wheel ribbed "can" removal [Re: roadrunninMark] #1190527
03/04/12 01:33 AM
03/04/12 01:33 AM
moparmarks Offline
moparmarks  Offline
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 barracuda steering wheel ribbed "can" removal [Re: roadrunninMark] #1190528
03/04/12 02:33 AM
03/04/12 02:33 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Sometimes bolts that long are hard to find in that thread size...just get some threaded rod,cut it to size, and use nuts and flat washers....
MB
Re: 71 barracuda steering wheel ribbed "can" removal [Re: HPMike] #1190529
03/04/12 03:52 AM
03/04/12 03:52 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I used to carry around a puller that I cut the ends off of so it would fit down in the can.
Water pump bolts are handy to use at the junkyard if you forgot yours at home.
Re: 71 barracuda steering wheel ribbed "can" removal [Re: NicksGarage] #1190530
03/04/12 02:34 PM
03/04/12 02:34 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I just cut the ends off a cheap puller to fit inside the can too.
