ARP MAIN CAP STUD KIT??? #1189684
03/02/12 03:03 PM
03/02/12 03:03 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
When is it needed for a 440...using the factory caps? The caps also need to be align-honed,after installed...am I correct? I was advised by an engine builder/machinist to make the switch..since adding a possible 90-100 horsepower with recent headwork. What is the concensus on this? Thanks in advance!
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189685
03/02/12 03:34 PM
03/02/12 03:34 PM
organ
maximum entropy Offline
organ
i always go with studs, and a bolt in girdle. if you have a dial bore gauge, and a straight edge, check the mains yourself. sometimes they need a to be line honed, sometimes not. always check.
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189686
03/02/12 03:58 PM
03/02/12 03:58 PM
What kind of maximum power will te motor make with the new heads? If less than 600 HP don't worry about it I have switch from main bolts to ARP main studs and didn't have the mains aligned honed, I did measure the main bore size before and after with a inside mike to see if it changed, it didn't
Re: ARP MAIN CAP STUD KIT??? [Re: Cab_Burge] #1189687
03/02/12 04:09 PM
03/02/12 04:09 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
I always stud the mains on anything over 500 hp. It is cheap insurance in my opinion. You may have to have it honed, mine needed it, don't just install them and assume it is all good! I am interested in possiby going to a girdle in the future, but I read so much contradictory stuff here, I am not sure which one to use. Good Luck on your build and your car looks great! Lee.
Re: ARP MAIN CAP STUD KIT??? [Re: Lee446] #1189688
03/02/12 04:32 PM
03/02/12 04:32 PM
organ
organ
nothing contradictory from me. i've installed a bunch, four different manufacturers. all with good results. i believe.
Re: ARP MAIN CAP STUD KIT??? [Re: maximum entropy] #1189689
03/02/12 04:44 PM
03/02/12 04:44 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I think if you are going to go with studs and line hone that it would be a good time to go with new main cap!
67' charger 499 RB 10.57 at 127
Re: ARP MAIN CAP STUD KIT??? [Re: dragram440] #1189690
03/02/12 05:01 PM
03/02/12 05:01 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks people! Matt..I think you're right! Just MORE ADDED INSURANCE!..sure can't hurt! Cab...guesstimating to be around 610-620 horsepower..at the crank,of course! Any suggestions on what aftermarket caps to buy/use??? THANKS! Randy B.
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189691
03/03/12 12:20 AM
03/03/12 12:20 AM
I like and use to buy, when they where still avaliable, the Mopar brand Ductile iron main caps. Buy them if you can find a set If not my next choice would be steel main caps. They're are a lot of other racers and engine guys on this site that I respect that have used aluminum main caps with no problems I'm not one of them, yet, so I can't and won't recommend parts that I haven't used
Re: ARP MAIN CAP STUD KIT??? [Re: Cab_Burge] #1189692
03/03/12 01:23 AM
03/03/12 01:23 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
What about the 440Source Billet Steel Caps? Any quality issues with these???
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189693
03/03/12 02:36 AM
03/03/12 02:36 AM
Oh
His and Her 69's Offline
Oh
Randy, Janet's RR had stock caps with ARP studs at 615 hp for 8 years and never a problem. The car had a LOT of 1/4 mile passes and a Bunch of road miles and some street test n tune sessions so it wasn't babied at all. It would be for your peice of mind only that I would tell you to get new caps.
I had alum caps and studs on my car at 771 hp and I used NOS also so that is why it had them. You will have some cap walk no matter what you use but it will be less the more you do to it over stock.
just my 2 cents.
David
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189694
03/03/12 04:54 AM
03/03/12 04:54 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Randy I am using the 440Source billet steel main caps. I also use the ARP main studs. Had all the mains align bored and honed to size. I am making right around 600 hp and so far everything is holding up great. No problems at all with the Source main caps with the ARP studs. I also like to use main studs with anything over 500 hp or any eng that is going to be raced. Ron
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189695
03/03/12 09:20 AM
03/03/12 09:20 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
Randy, I have the stock mains with CRE's stud/girdle kit...we made 760hp on our first pull..the engine was installed in the car to break it in with a few runs and then it was re-tuned giving it another 100hp+...
that engine has been sitting and will be going into my Dodge..I started thinking about the street activity and trips to the track...I am going to order the BCR "bottom" kit that comes with the full "wall to wall" main caps and that 1/2" thick girdle...thats a well planned out bottom end for our stock blocks with 2 main bolts/studs..
no matter what you do, a stud/girdle to me, is a must...
Re: ARP MAIN CAP STUD KIT??? [Re: smokinwoody] #1189696
03/03/12 10:49 AM
03/03/12 10:49 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
Smokinwoody, does this 1/2" girdle cause any clearance issues with oil pans or anything?
Re: ARP MAIN CAP STUD KIT??? [Re: JackGTX440] #1189697
03/03/12 12:06 PM
03/03/12 12:06 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Randy
I'm using ARP kit with BCR alum cap & girdle kit for years in the Coronet.I also have a half fill of hard block.
All comes down to what you want, there's a couple sets of aftermarket caps for sale on here too.Like mentioned it's money well spent imo to keep things together.
Re: ARP MAIN CAP STUD KIT??? [Re: Blown 68 R/T] #1189698
03/03/12 12:39 PM
03/03/12 12:39 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks guys! So,Ron..the quality and fitment on the Source caps was good,I'm assuming?! Jeff..AWESOME set-up!...but with my power level(600-620hp)and "shoestring budget" I'm thinkin' the ARP stud kit,and billet caps would be a BIG improvement over my stock caps,and ARP bolts. JACK!!!...where you been hiding? Please say HELLO to your father for me! I have to get with Paul shortly...motorcycle parts my brother left for him! Kevin..those BCR caps look GREAT!...but for as often as I race,and the difference in prices..I just might have to use the Source caps! Being on a fixed income SUCKS! Thanks again for your ideas,and info! Randy B.
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189699
03/03/12 01:42 PM
03/03/12 01:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Randy I took my block with the 440Source main caps right to the machine shop to be align bored and have the ARP studs put in. I never really tried the caps before that but they fit great when I got my block back. Ron
Re: ARP MAIN CAP STUD KIT??? [Re: 383man] #1189700
03/03/12 02:03 PM
03/03/12 02:03 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Ron! I'm really leaning towards the Source caps! $140.00 a set IS an EXCELLENT price for Billet caps! Gotta be stronger than the factory caps!...especially with the stud kit installed!
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189701
03/03/12 04:55 PM
03/03/12 04:55 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I am leaning toward recommending to just put ARP studs in it and hone if necessary. Take us a few snapshots of ALL main cap parting surfaces and post them. If all is good STAY AWAY from detonation. Machine for quench,(hopefully noone beveled the top of the bore) draw-in cool air ONLY, and be conservative with the timing to include minimizing spark scatter.
Re: ARP MAIN CAP STUD KIT??? [Re: HardcoreB] #1189702
03/03/12 05:19 PM
03/03/12 05:19 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for chiming in,Shawn! I'll run out to the pole barn in a few minutes and take some shots of ALL the cap mating surfaces. I can definately see evidence of "walking" on #2..#3..and #4 block/cap mating surfaces! So..you think just the stud kit alone will eliminate the "walking" issue? BTW...after talking to Randy Thursday...I will be going with Shawn at St. Clair Engine, to be doing my machine work!..he seems to be Mopar-Connected,for sure!
Re: ARP MAIN CAP STUD KIT??? [Re: Labratt] #1189703
03/03/12 07:23 PM
03/03/12 07:23 PM
Get a real good flat mill file and remove any of the material that transferred betweent the caps and block mating surfaces, don't go hog wild, just smooth them up so they are flat
