74 Dart fan motor removal.
#1189236
03/01/12 07:07 PM
03/01/12 07:07 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Hi all. Does the fan motor on my 74 Dart come out from the engine compartment side. The way the motor and flange is bolted to the firewall makes it look like it I could just take the nuts off and slide it right out. It looks and sounds too easy but thought I would ask. If it does come out this way is there anything I should be cautious of or any tips?
Thanks everyone!:)
BigBlock 74 Swinger
Re: 74 Dart fan motor removal.
[Re: bb74swngr]
#1189237
03/01/12 07:13 PM
03/01/12 07:13 PM
Posts: 804 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
I'm fairly sure your 74 is the same as my 69. It comes out from the inside with the entire heater box assembly. Undo the 4 nuts around the blower motor and the retaining plate where the heater hoses connect to the firewall. Then open the passenger side vent door and undo the j-bolt located inside. Once all that is done gently work it out enough to undo the heater cables and electrical connections and it should come out(mine is a non-ac car, the ac cars are a bit more complicated). Mines out currently restoring the box and replacing the core, motor and seals. Good luck!
1972 Road Runner
1988 Shelby CSX-T
[Re: racerx20]
#1189239
03/01/12 07:21 PM
03/01/12 07:21 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks Joey. Are the J-bolts you refer to used to hold the whole unit in under the dash? Is it hard to find all of them or is obvious where they are located?
Russ...
BigBlock 74 Swinger
[Re: stumpy]
#1189240
03/01/12 07:27 PM
03/01/12 07:27 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks Richard. I saw the gasket or sealer around the flange and will try to save it. I have had two responses with different thoughts so I think I will just tear into it and see what happens. I hope your experience will be the same for my car.
Thanks so much...
BigBlock 74 Swinger
[Re: stumpy]
#1189242
03/01/12 07:30 PM
03/01/12 07:30 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
That is great! Thank you so much Richard for going to all that trouble...great news!
Russ:)
BigBlock 74 Swinger
[Re: bb74swngr]
#1189243
03/01/12 07:34 PM
03/01/12 07:34 PM
racerx20
Standard but OK
Standard but OK
Houston, Texas
My 69 service manual states in the blower motor removal section... 1-Remove heater as outlined in "Heater Removal".
But the 74 may be different I have never owned one. The J-bolt is obvious, just open the door and look inside. The bolt head is on the bottom of the box. I would undo this one last.
edit: just saw Stumpy's last post, try that route first, good luck!
1972 Road Runner
1988 Shelby CSX-T
[Re: racerx20]
#1189244
03/01/12 07:38 PM
03/01/12 07:38 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Thanks again Joey. I am going to give it a try from the engine compartment...fingers are crossed, and yes I know it's harder to work with your fingers crossed. JK!
Russ:)
BigBlock 74 Swinger
[Re: stumpy]
#1189246
03/01/12 07:45 PM
03/01/12 07:45 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
Richard, not only did I read it but saved a copy! I'm old and forget very easy:) I hope you didn't take that out of your manual just to make a copy:/ It sounds very straight forward and just as I had hoped.
Thanks again for your valuable time... Russ:)
BigBlock 74 Swinger
