Re: any gains going from 4.10 to a 4.30 gear
[Re: mopar dave]
#1188929
03/01/12 08:38 AM
03/01/12 08:38 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I run 4.30 and 4.10 gears. No difference in et. , only a 200 rpm difference at the stripe. I usually run 4.30 gears, and the 4.10 are my extra set.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: mopar dave]
#1188930
03/01/12 09:31 AM
03/01/12 09:31 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You can expect to run about .76% faster if your at 12.000 should hall to 11.90 10.55 to 10.46 That is assuming it does not cause spin or run out of wind top end and all else stays the same!
[Re: Otherlane]
#1188933
03/01/12 11:27 AM
03/01/12 11:27 AM
Posts: 16,936 NC
440Jim
NC
Is there a rule of thumb for gear changing? like one member said he didnt get any ET but there is a 200 rpm difference.is it for every gear change so does 200 rpms?
You can use the web calcs given above. But the pure gear change equation is:
RPM1:RPM you run with gear set 1 (G1) RPM2:RPM you run with gear set 2 (G2) MPH1:MPH you run with gear set 1 MPH2:MPH you run with gear set 2
RPM2 = MPH2/MPH1 x RPM1 x G2/G1
For example, If you run 130 MPH1 with 4.10 Gear1 at 7000 RPM1, and if your MPH doesn't change, ie MPH2=MPH1, then:
RPM2 = 130/130 x 7000 x 4.30/4.10 = 7341
The question of if your MPH changes depends on your car's combo. Also, in some applications the converter slip will change; which changes RPM
[Re: mopar dave]
#1188935
03/01/12 12:38 PM
03/01/12 12:38 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
anyone have an ET gain going from 4.10 to 4.30 gear?
To make a long story short, it's like most other things......
It's combination specific, as there are too many variables to make a definitive response. What works on one deal, may not on another.
It takes time and money to cycle parts and make calculated/accurate comparisons, but that's what it takes to sort out any combination.
Bottom line......try it and see what happens.
[Re: mopar dave]
#1188937
03/01/12 03:21 PM
03/01/12 03:21 PM
Posts: 43,693 Bend,OR USA
Cab_Burge
My car, 518 pump gas stroker, 3450 lbs Duster, ran almost (within hundreds ands less than .25 MPH) the same with 3:73,3:91,4:10 and 4:30 Low tens at 128.+ MPH I do run the Mopar 2:77 low gear set in the trans so that may play into the results, the car usualy didn't spin no matter which rear gear was in it ,
[Re: Cab_Burge]
#1188940
03/01/12 09:39 PM
03/01/12 09:39 PM
Posts: 16,936 NC
440Jim
NC
Good example how different combos will respond differently. I had similar results with 3 gear ratios, 4.10, 4.30 and 4.56, the car didn't like high rpm and didn't need anymore torque multiplication at the start. Big torque motors with 3 speed auto transmissions may not be as sensitive as small cube/torque applications.
[Re: tboomer]
#1188943
03/02/12 10:31 AM
03/02/12 10:31 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
Pretty interesting...I would like to change the 4.88s out and go with a 4.30...
why so much gear Ted...how big are the rear tires...
