Re: any gains going from 4.10 to a 4.30 gear
[Re: mopar dave]
#1188929
03/01/12 08:38 AM
03/01/12 08:38 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I run 4.30 and 4.10 gears. No difference in et. , only a 200 rpm difference at the stripe. I usually run 4.30 gears, and the 4.10 are my extra set.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: mopar dave]
#1188930
03/01/12 09:31 AM
03/01/12 09:31 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
You can expect to run about .76% faster if your at 12.000 should hall to 11.90 10.55 to 10.46 ![](/ubbthreads/images/graemlins/Twocents.gif) That is assuming it does not cause spin or run out of wind top end and all else stays the same!
[Re: Otherlane]
#1188933
03/01/12 11:27 AM
03/01/12 11:27 AM
Posts: 16,934 NC
440Jim
NC
Is there a rule of thumb for gear changing? like one member said he didnt get any ET but there is a 200 rpm difference.is it for every gear change so does 200 rpms?
You can use the web calcs given above. But the pure gear change equation is:
RPM1:RPM you run with gear set 1 (G1) RPM2:RPM you run with gear set 2 (G2) MPH1:MPH you run with gear set 1 MPH2:MPH you run with gear set 2
RPM2 = MPH2/MPH1 x RPM1 x G2/G1
For example, If you run 130 MPH1 with 4.10 Gear1 at 7000 RPM1, and if your MPH doesn't change, ie MPH2=MPH1, then:
RPM2 = 130/130 x 7000 x 4.30/4.10 = 7341
The question of if your MPH changes depends on your car's combo. Also, in some applications the converter slip will change; which changes RPM
[Re: mopar dave]
#1188935
03/01/12 12:38 PM
03/01/12 12:38 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
anyone have an ET gain going from 4.10 to 4.30 gear?
To make a long story short, it's like most other things......
It's combination specific, as there are too many variables to make a definitive response. What works on one deal, may not on another.
It takes time and money to cycle parts and make calculated/accurate comparisons, but that's what it takes to sort out any combination.
Bottom line......try it and see what happens.
[Re: mopar dave]
#1188937
03/01/12 03:21 PM
03/01/12 03:21 PM
Posts: 43,528 Bend,OR USA
Cab_Burge
My car, 518 pump gas stroker, 3450 lbs Duster, ran almost (within hundreds ands less than .25 MPH) the same with 3:73,3:91,4:10 and 4:30 Low tens at 128.+ MPH I do run the Mopar 2:77 low gear set in the trans so that may play into the results, the car usualy didn't spin no matter which rear gear was in it ,
[Re: Cab_Burge]
#1188940
03/01/12 09:39 PM
03/01/12 09:39 PM
Posts: 16,934 NC
440Jim
NC
Good example how different combos will respond differently. I had similar results with 3 gear ratios, 4.10, 4.30 and 4.56, the car didn't like high rpm and didn't need anymore torque multiplication at the start. Big torque motors with 3 speed auto transmissions may not be as sensitive as small cube/torque applications.
[Re: tboomer]
#1188943
03/02/12 10:31 AM
03/02/12 10:31 AM
Posts: 12,339 somwhere
smokinwoody
somwhere
Pretty interesting...I would like to change the 4.88s out and go with a 4.30...
why so much gear Ted...how big are the rear tires...
