Re: WELDED K member pictures
[Re: Kern Dog]
#1188801
03/28/12 08:14 PM
03/28/12 08:14 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You could still run a plate on the forward side of that steering box mount. Be worth it especially with a Pachyderm in there.
Mopar to the bone!!!
Post deleted by moparts
[Re: Stanton]
#1188804
03/31/12 02:32 PM
03/31/12 02:32 PM
#1188805
03/31/12 03:32 PM
03/31/12 03:32 PM
Posts: 9,097 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I guess you have never seen an UNsupported one rip out?
Well the key word here is "unsupported". Properly welded, those tubes would never fail. Anyhow, it's my opinion and I'm sticking to it. Don't like it ... tough!
[Re: Stanton]
#1188806
03/31/12 05:33 PM
03/31/12 05:33 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
3. Known/reported failure of any mopar k member structural spot welds is rare or non existent
I'm not a corner guy, more of a drag racer. In my early 20s (early 90s) I beat my 73 Dart Sport 340 4 speed car WITHOUT mercy. On the track and on the street. Ripping through the gears nearly all the time. Nothing too fast, just a low, low 13 second car. Any way, one time, after leaving my GF's house, when I finally got to the main road and pulled out, I ripped through the gears as usual. Then I had to slow down for a traffic light. All of a sudden, the FRONT tires are squealing and brakes are not locked up. So I pull into a convenience store and get out to see what's going on. Both front tires are leaning out at the top or the bottom of the tires were tucked in. I called a friend for a tow. Turns out, BOTH lower control arm tubes cracked and ripped out of the K-frame. I got another K-frame from a local used Mopar parts vendor. The K-frame that he pulled to sell to me was already cracked on one of the LCA mounts. I had him pull another K-frame for me. We welded washers to it so it wouldn't happen again. This is all long before internet forums.
[Re: Stanton]
#1188807
04/01/12 01:35 AM
04/01/12 01:35 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I ran 75/25 gas, the k member was hot tanked but there was some oil still seeping out from between the flanges, I was also welding outside and a slight breeze could affect the shielding gas. I did weld up the LCA mounts because the factory welds were crap, undercut in spots and poor penetration. Tim Quote:
Personally I wouldn't weld washers to the LCA points. The tubes welded into the K will do a fine job of handling and spreading the load. If there had been no tubes then that area would definitely need to be beefed up. Otherwise, nice job. If you switch to a mixed gas next time you need a bottle, you'll find a HUGE improvement in your weld appearance - there is virtually ZERO spatter with a mix. Additional cost ... shouldn't be a factor unless you're a production shop. The way I look at it, the time I save not having to clean up spatter is well worth any additional cost.
[Re: JDMopar]
#1188809
04/01/12 02:19 PM
04/01/12 02:19 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The factory welds WERE properly welded at the time the cars were built.
Are you kidding us ?!?!? The quality of welding on K-members is pathetic - the reason most guys reweld them!
[Re: Stanton]
#1188810
04/01/12 03:00 PM
04/01/12 03:00 PM
[Re: Stanton]
#1188812
04/02/12 12:27 AM
04/02/12 12:27 AM
[Re: astjp2]
#1188816
04/05/12 06:54 PM
04/05/12 06:54 PM
72Swinger
Nebraska
Did up my 72 Dart K frame today.
[Re: 72Swinger]
#1188817
04/05/12 06:56 PM
04/05/12 06:56 PM
72Swinger
Nebraska
And the front. You can also see the idler arm bracket I modified to clear the Road Race pan.
[Re: 72Swinger]
#1188818
04/06/12 03:47 AM
04/06/12 03:47 AM
Posts: 27,596 So Cal
autoxcuda
So Cal
Is that's a big block K-member? Is that why it's modified to fit a big block in an A-body?
