neon Transmission Solenoid,bad? #1188730
03/01/12 12:47 AM
03/01/12 12:47 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
i hav an 05 neon and the transmission solenoid leaks, i think i was told that when i got the car a few years ago. i was wondering since i am pulling the motor now anyway, what happens if the soleniod goes bad? can it do transmission damage?
thanks
Re: neon Transmission Solenoid,bad? [Re: dirt] #1188731
03/01/12 01:19 PM
03/01/12 01:19 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
Re: neon Transmission Solenoid,bad? [Re: dirt] #1188732
03/01/12 01:26 PM
03/01/12 01:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have seen alot of them leak over the years. You have to replace it. It will come with a new gasket and if it has the plate between the solenoid pack and the trans case you just throw the plate away as you dont use it with the newer solenoid packs. Ron
Re: neon Transmission Solenoid,bad? [Re: 383man] #1188733
11/30/12 09:40 PM
11/30/12 09:40 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
what happens when the solenoid goes bad?
Re: neon Transmission Solenoid,bad? [Re: dirt] #1188734
12/01/12 11:11 PM
12/01/12 11:11 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
it can throw you neon in limp mode.. so u should fix it now..
Re: neon Transmission Solenoid,bad? [Re: Dakota_Don] #1188735
12/01/12 11:16 PM
12/01/12 11:16 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
it's basically you're valve body. if something fails. it will go into limp mode.which means you'll have 2nd gear only.they do go bad often.
Re: neon Transmission Solenoid,bad? [Re: moretoys] #1188736
08/01/13 04:37 PM
08/01/13 04:37 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
the last time I drove the neon it only had 1 gear so I think its finally time to change the solenoid pack.
is this a fairly simple job? it looks like it should not be too difficult.
Re: neon Transmission Solenoid,bad? [Re: dirt] #1188737
08/01/13 04:56 PM
08/01/13 04:56 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I've never done one but I assume its fairly simple. My stepson had it done and was only charged $50 by a trans shop
Re: neon Transmission Solenoid,bad? [Re: GTXKen] #1188738
03/26/14 11:10 PM
03/26/14 11:10 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
just an update. I changed the solenoid and it was super easy to get to , I didn't even have to jack the car up.
that was all that was wrong and it shifts fine now.
