86 turbo z won't idle???
#1188630
02/29/12 09:15 PM
02/29/12 09:15 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
buddy just bought this car.clean- maintained car.did a timing belt as maintenance,a few days later in the colder weather,won't idle,just goes up- down,up down, stalls,nothing consistent.sometimes it's rich sometimes lean.It also has a hesitation. I've checked and repaired all the vacuum lines, t-body is clean,But I also installed a different one that I had with all sensor still attached.Used 2 full cans of carb cleaner,A vacuum leak does not show up.I know these also have problems with the map sensor and lines since they are so long and go on the logic module inside.I have a good reading on the scan tool.I also noticed that there is a reman power module next to the battery.Runs good and strong,just NO idle.I did the relearn, didn't help.timing is right on.belt is right. done hundreds of these.Egr valve seems to be closed.I do hear a slight exhaust leak.Can something in the turbo cause a problem?? I'm out of basic ideas. TURBO dodge forum was no help either.
Re: 86 turbo z won't idle???
[Re: moretoys]
#1188635
03/01/12 02:47 AM
03/01/12 02:47 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I don't know if this thing has an idle air control valve, but if it does you need to look at it. If it's sticking or just blown to crap you will never get a consistent idle.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
