8 3/4 diff lube #1188374
02/29/12 03:48 PM
02/29/12 03:48 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Im sure this has been asked a hundred times but what is everyone using for diff lube in a 8 3/4 suregrip and how much? Thanks Clay
Re: 8 3/4 diff lube [Re: Clayton] #1188375
02/29/12 04:59 PM
02/29/12 04:59 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
80/90 would be correct, but you could use a synthetic that was different than that without issue. They don't care a bunch really.
Make sure you use a limited slip additive if you have a sure grip, regardless of whether the oil says you need it or not. It won't hurt anything, and it might chatter without it.
Re: 8 3/4 diff lube [Re: Clayton] #1188376
02/29/12 06:00 PM
02/29/12 06:00 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Regarding "how much"....
I get a gallon along with the hand pump. I just fill it until it starts to seep from the fill hole. Its usually around 2 1/2 quarts. A wide C body will take more than a narrowed A body housing. ALSO, make sure that the car is sitting level or close to it.
