Jegs windage tray/gasket with stock oil pan #1188278
02/29/12 02:53 PM
02/29/12 02:53 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
I was curious if anyone has used the Jegs windage tray/gasket with a stock oil pan? I called and asked, of course they said it does, but I was hoping for some real world experience. It's going on a 70 hemi with a stock pan.
-Chris
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188279
02/29/12 03:28 PM
02/29/12 03:28 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
do you have a part# i didnt know jegs had there own tray? milodon-moroso??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Jegs windage tray/gasket with stock oil pan [Re: 440lebaron] #1188280
02/29/12 04:58 PM
02/29/12 04:58 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Just bought one yesterday and awaiting arrival. Here is the part # in Jeg's catalog. By the way...Jeg's is the only place you can get this item. No place else....
555-502000 WIND TRAY 3.75 B/RB/HEMI 69.99
Re: Jegs windage tray/gasket with stock oil pan [Re: CR8CRSHR] #1188281
03/01/12 04:34 PM
03/01/12 04:34 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Thats the one. I have it here already, I'm just not too pleased with the way the gasket ribs line up with the pan rail. I was hoping someone has one on a running engine for feedback.
-Chris
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188282
03/01/12 04:49 PM
03/01/12 04:49 PM
New State
kidmopar Offline
kidmopar  Offline
New State
-Chris
Re: Jegs windage tray/gasket with stock oil pan [Re: kidmopar] #1188283
03/01/12 05:08 PM
03/01/12 05:08 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is that the one that is the windage tray with the gaskets made on both sides of it ? If it is I have that here as my buddy dropped it off for me to use on his eng when I replace the rear main seal. Ron
Re: Jegs windage tray/gasket with stock oil pan [Re: 383man] #1188284
03/01/12 07:28 PM
03/01/12 07:28 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Yes that's the one. I can see that it would work great if you had a flat pan rail like on an aluminum pan, not so sure about the stocker.
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188285
03/01/12 08:34 PM
03/01/12 08:34 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Nevermind, I answered my own question. Put grease on the oil pan and installed it to see where it left marks. Practically the whole side of the oil pan is missed by the gasket, except around the bolt holes. I'll post pics to show what I'm talking about.
Great idea, garbage execution. 0 for 2, junk mancini rear main seal and junk jeg's oil pan gasket.
One day maybe some one will start making stuff that actually works.
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188286
03/01/12 09:49 PM
03/01/12 09:49 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Pix attached....I mocked one up and it looked awesome - double-lip silicone seals, torque-limiting grommets. Hard to see how this can fail to seal....?
Rick
Re: Jegs windage tray/gasket with stock oil pan [Re: Rick_Ehrenberg] #1188287
03/01/12 09:59 PM
03/01/12 09:59 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I could see how those raised beads will miss the dimpled area of the pan rail
Don't know if you have a stock steel pan or an aftermarket repop or performance but i've experienced issues with a repop "402" that wasn't straight
I offer a nice pan gasket and a premium rear seal if you have a need
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188288
03/01/12 10:08 PM
03/01/12 10:08 PM
crisfield, maryland 21817
8
82ramIndy493 Offline
Thats because its a Mopar part. If it was a Chevy or Ford part it would have been made to perfection.
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188289
03/02/12 08:22 AM
03/02/12 08:22 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Hi,
Here's another thread about this windage tray.
Jegs Windage Tray
I just finished putting one on my 400 with a factory 402 pan. The pan rail was pretty straight but with the thickness of this composite tray, I'm sure some minor dimpling would still be resolved.
I have about an hour's worth of run time with the car on jack stands and probably another hour this weekend while I finish some other work. So far, no leaks and I've checked the pan rail area pretty closely. I'm very satisfied with this, especially considering the price.
If someone wants, I can post a picture of the pan rail area to show the thickness of this part once it's installed.
Mike.
Re: Jegs windage tray/gasket with stock oil pan [Re: moparmike1] #1188290
03/02/12 01:08 PM
03/02/12 01:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Thank you for the feedback, pics would be great.
Re: Jegs windage tray/gasket with stock oil pan [Re: Jeremiah] #1188291
03/02/12 03:53 PM
03/02/12 03:53 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Here are some pictures of what I'm talking about. I just can't see how this is going to seal and this car CAN'T leak! I don't have the luxury of being a guinea pig.
You can see there are a couple areas where the gasket actually misses the pan completely. It would seal around the bolts pretty good. If they just made it fit a stock pan then it would probably fit pretty much anything.
And just for good measure here is the wiz bang Mancini rear main that doesn't work either. Side seals don't seal, retainer runs into the main cap AND the crank. It actually ground a bunch of aluminum off and packed it in the seal.
Re: Jegs windage tray/gasket with stock oil pan [Re: Dukes69] #1188292
03/02/12 06:30 PM
03/02/12 06:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Dukes69 that's exactly what I was refering to in the beads not sealing the pan in your first pic.
I assume the Mancini seal retainer also uses the o-ring cord for the side seals, very problematic IMHO.
Please click the link for some rear main seal help. The stock retainers are actually not that bad to work with if they are not beat up too bad.
Stud clearacne is an issue and should always be checked.
https://board.moparts.org/ubbthreads/show...t=1#Post5800228
Re: Jegs windage tray/gasket with stock oil pan [Re: roadhazard] #1188293
03/02/12 08:14 PM
03/02/12 08:14 PM
Temecula, CA
Dukes69 Offline OP
Dukes69  Offline OP
Temecula, CA
Thanks for the link. The Mancini retainer was actually hitting the main cap itself, not the bolts (stock main bolts).
Re: Jegs windage tray/gasket with stock oil pan [Re: Jeremiah] #1188294
03/04/12 08:30 PM
03/04/12 08:30 PM
moparmike1 Offline
moparmike1  Offline
Hi,
Here are a few pictures to show the gasket with my oil pan.
Chris, I'm not sure what pan you have but you can see the gasket matches the rail on mine really well and it's like this all the way around. When you compare how close my pan is to the back of the block and then look at yours, it's definitely shaped different.
So far, no leaks. I would recommend the gasket.
I'll post a few more pictures.
Mike.
Re: Jegs windage tray/gasket with stock oil pan [Re: moparmike1] #1188295
03/04/12 08:31 PM
03/04/12 08:31 PM
moparmike1 Offline
moparmike1  Offline
Another picture.
Re: Jegs windage tray/gasket with stock oil pan [Re: moparmike1] #1188296
03/04/12 08:33 PM
03/04/12 08:33 PM
moparmike1 Offline
moparmike1  Offline
Picture #3.
Re: Jegs windage tray/gasket with stock oil pan [Re: moparmike1] #1188297
03/04/12 08:34 PM
03/04/12 08:34 PM
moparmike1 Offline
moparmike1  Offline
Last one.
