Making a wiring harness #1188242
02/29/12 01:12 PM
02/29/12 01:12 PM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
Is is possible to custom build a wiring harness for a customized car? I could buy an original wiring harness, but would have to modify it. Rather than modify an original harness, it may be better to start with a blank page.
So my questions, Is this a practical idea? Where would I find quality wiring components? Are the plastic ends available which plug onto various components on the car such as the transmission, electrical motors, etc.
Re: Making a wiring harness [Re: QuickDodge] #1188243
02/29/12 01:48 PM
02/29/12 01:48 PM
Andrewh Offline
Andrewh  Offline
it depends.
if you mean for the whole car end to end, I am not sure if it is worth it.
expense wise, there are plenty of kits out there that you can modify to your hearts desire that are cheaper than you can build it yourself.
if you mean something like an engine harness or tail light harness, then sure. I wouldn't bother to use factory ends unless I need them, and then I would just take apart the original and make new ends using those connectors. for the rest I would use weather pac connectors.
I rebuilt my own tail light harness doing that and using new tail light ends.
BUT I only had to deal with 4 colors of wires.
An under dash harness is probably 15 or so colors with and without tracers.
Can be done, and honestly could be simplified quite a bit with a few relay's etc.. but would be expensive due to the sheer number of spools of wire required.
the common ends are available at napa, but you have to take appart the plastic part of the connectors to reuse them.
some simple tools allow you to do it pretty easy.
If it were a completly custom car, then you really don't have a choice but to wire your own. But you would be better off not to limit yourself to the stock connectors unless you have to plug into something factory as chrysler is a pain about allowing someone to make the correct connectors.
that is why most aftermarket universal wiring harnesses use GM stuff.
Re: Making a wiring harness [Re: Andrewh] #1188244
02/29/12 02:02 PM
02/29/12 02:02 PM
Yes you can do it & it'd let you go a gauge larger (2 #'s actually) and NAPA has the 1/4" brass terminals and the old ones can be easily removed from connectors w an eyeglass mini screwdriver but what Andrew said the sheer # of spools would be pricey & you DO want to use the same exact colors/tracers as originals were. I did it once & it was alot of work but now the car is up to snuff and original gauge sizes were barely adequate in some circuits. There are companies that will sell you lengths of the color/tracer of wire you specify & that's the way I'd go next time
Re: Making a wiring harness [Re: QuickDodge] #1188245
02/29/12 02:02 PM
02/29/12 02:02 PM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
Personally, I like making my own harnesses...I like being able to custom tailor to suit my needs, resulting in no unnessary wiring and a neater appearance. You can find good weather sealed harness plugs on eBay for cheap, and you can buy wire in larger quantities on eBay and have more than enough....just my preference though.
Re: Making a wiring harness [Re: QuickDodge] #1188246
02/29/12 02:43 PM
02/29/12 02:43 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
guess it depends what exactly you want to do..
i went with the american auto wire highway 22 kit. it will do anything i need it to do and probably more. it adapted to my dart very easily.
link to the kit: http://www.americanautowire.com/highway22.html
some pics and a brief description: http://www.automotiverewire.com/Navagation/Joes71Dart.htm
some diagrams we made up that may help ya no matter what way you decide to go...
http://www.automotiverewire.com/Documents/71DartColumnPlug.pdf
http://www.automotiverewire.com/Documents/71DartIgnitionWiring.pdf
http://www.automotiverewire.com/Documents/71DartCharging.pdf
http://www.automotiverewire.com/Documents/71DartInteriorLighting.pdf
http://www.automotiverewire.com/Documents/71DartDelay.pdf
here is the article that was done on us wiring the car...
http://www.automotiverewire.com/Documents/AutoEnthusiast2011.pdf
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Making a wiring harness [Re: abodyjoe] #1188247
02/29/12 03:56 PM
02/29/12 03:56 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Hybrid is a better approach. Try a kit that has all the circuits you need plus a couple extra and then make all the new ends or tap into factory lighting harnesses. I used Kwikwire, they are like $300.00. It still ends up being quite custom. I know my car wouldn't be stick, the battery was going in the trunk with a relay, I was installing an under hood relay/fuse box for lights and HD accessories, radio was going in the glove box, MSD and coil in the car etc... http://www.kwikwire.com/wh_22Circuitstreetrodwiring.html
Re: Making a wiring harness [Re: GTXKen] #1188248
02/29/12 05:23 PM
02/29/12 05:23 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
I wired my A-100 from scratch using quality wires and modernized components. I would suggest against doing it, because of the cost. Get a good kit with GXL wires and good fuse block, and modify it.
Good luck,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: Making a wiring harness [Re: kick_the_reverb] #1188249
02/29/12 08:53 PM
02/29/12 08:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I just did my 64. The only OE part I used was the right to left tail lamp harness. Built the engine harness in my Challenger as well.
Doug
Re: Making a wiring harness [Re: dvw] #1188250
02/29/12 09:09 PM
02/29/12 09:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
dash
Re: Making a wiring harness [Re: dvw] #1188251
02/29/12 09:10 PM
02/29/12 09:10 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
better trunk
Re: Making a wiring harness [Re: dvw] #1188252
02/29/12 09:11 PM
02/29/12 09:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Firewall from the back and thru the frame rail out front
Re: Making a wiring harness [Re: dvw] #1188253
03/01/12 11:21 AM
03/01/12 11:21 AM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
dvw, WOW! that is very nice work! I'm embarrassed to show my wiring now! I did a ProStreet Camaro wiring from scratch, well sort of. I used an "Enos" (enoscustom.com) panel and wired the rest myself. Might want to check that out. Very easy to do and very nice instructions too. Take care, Jeff
