1968 superbee #1188123
02/29/12 10:40 AM
02/29/12 10:40 AM
New York
buck0123 Offline OP
buck0123  Offline OP
New York
Anyone know why when I drive my car with the windows down I get exhaust fumes inside?
1968 Dodge superbee
383 Auto
Med. Gold Metalic paint
Re: 1968 superbee [Re: buck0123] #1188124
02/29/12 10:46 AM
02/29/12 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Seals/gaskets ... rust pin holes in the trunk floor ... in the back of the car , trunk lid and tail lights , have the same problem with my bee, can't drive it wit ha window cracked , both have to be all the way down , I'm going to tackle that issue when it goes back together .
Re: 1968 superbee [Re: JohnRR] #1188125
02/29/12 12:19 PM
02/29/12 12:19 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
If you have a holley carburator it might have a blown power valve causing to rich of fuelmixture at idle and slow speeds , this will cause alot of fumes to come from under the car and in to the windows .
I had it happen to me before fixed the carb problems solved .
1969 Dodge Charger 1969 Dodge Superbee
