Axle hop #1187946
02/29/12 01:42 AM
02/29/12 01:42 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Not to long ago, I did an axle flip on the old truck to lower it, and also used drop shackles. The axle was originally under the leaf springs, now its rests on top. Ever since the flip, If I "accidentally" break traction, it starts to hop really bad. It starts off spinning, then begins to hop so bad it feels like something is gone break..any ideas what the cause would be, and what can I do to prevent it??
Re: Axle hop [Re: '84 D150 Shorty] #1187947
02/29/12 01:45 AM
02/29/12 01:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is it possible that the driveline angle is out of whack? This could cause voodoo harmonics due to an incorrect pinion angle.
Re: Axle hop [Re: Kern Dog] #1187948
02/29/12 01:49 AM
02/29/12 01:49 AM
TN
Pickup Man
Pickup Man
TN
Yikes..I never really measured..I basically eye balled it..I didn't really think a few degrees would matter much..
Re: Axle hop [Re: '84 D150 Shorty] #1187949
02/29/12 01:55 AM
02/29/12 01:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
when you did you flip remove any leaves to help in the drop??
I am truckless..
Re: Axle hop [Re: '84 D150 Shorty] #1187950
02/29/12 01:55 AM
02/29/12 01:55 AM
TN
Pickup Man
Pickup Man
TN
This is gonna make me sound like a tard... how to I properly measure my pinion angle?
Re: Axle hop [Re: 340SHORTY] #1187951
02/29/12 01:56 AM
02/29/12 01:56 AM
TN
Pickup Man
Pickup Man
TN
No, I didn't remove any leaves.
Re: Axle hop [Re: '84 D150 Shorty] #1187952
02/29/12 02:07 AM
02/29/12 02:07 AM
TN
Pickup Man
Pickup Man
TN
I wanted to point out also, that under normal and even HARD acceleration, I have no unusual vibration or harmonics..this happens ONLY when I lose traction.
Re: Axle hop [Re: '84 D150 Shorty] #1187953
02/29/12 02:09 AM
02/29/12 02:09 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
you need more HP to keep them spinning.
I am truckless..
Re: Axle hop [Re: 340SHORTY] #1187954
02/29/12 02:17 AM
02/29/12 02:17 AM
TN
Pickup Man
Pickup Man
TN
I can get them spinning good, but its like the tires starts trying to bite, and its all she wrote. I have to let off or I'm sure something will break...
Re: Axle hop [Re: '84 D150 Shorty] #1187955
02/29/12 08:41 AM
02/29/12 08:41 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
You could try clamping the springs in front of the axle. Do the shocks have plenty of travel?
Re: Axle hop [Re: bobby66] #1187956
02/29/12 12:05 PM
02/29/12 12:05 PM
TN
Pickup Man
Pickup Man
TN
Yes, BUT the axle does not have much room...I think maybe 2 inches..is it possible that the truck is squatting hard enough to sit the axle on the frame, effectively canceling out the shock absorption of the suspension?? That would definitely cause axle hop wouldn't it?
Re: Axle hop [Re: '84 D150 Shorty] #1187957
02/29/12 02:15 PM
02/29/12 02:15 PM
TN
Pickup Man
Pickup Man
TN
This is my cleareance, axle to frame. This is as it sits, on the ground, does this cleareance look adequate?
Re: Axle hop [Re: '84 D150 Shorty] #1187958
02/29/12 04:05 PM
02/29/12 04:05 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
This is just spitballin' here, but what if your shocks have a dead spot in them? I have seen and OWNED some shocks that worked fine in most situations, but when I removed them, they had some free play in them.
Also, Is it possible that you have NO pinion snubber and the axle radically ROTATES when the tires get a good bite? Basically, the axle yoke where the driveshaft connects tries to go up and down rapidly? If that is the case, maybe a fabbed up pinion snubber would help.
Re: Axle hop [Re: Kern Dog] #1187959
02/29/12 04:37 PM
02/29/12 04:37 PM
TN
Pickup Man
Pickup Man
TN
Hmmm...come to think of it, I fairly certain the truck never had a snubber to begin with...maybe a tabbed snubber as you suggested coupled with some traction bars to help prevent the leaves from trying to wrap? Anybody gotta pic of a typical snubbed/mount location?
Re: Axle hop [Re: '84 D150 Shorty] #1187960
02/29/12 04:59 PM
02/29/12 04:59 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
as you said, trucks dont have snubbers. you will have to fab something for the snubber to hit when you launch. Does you axle even have the holes to bolt a snubber to? Personally Id run some slapper bars for the old school look. They are very easy to build.I would take the old spring mout off for more clearance..
I am truckless..
