FRAME CONECTORS #1187815
02/28/12 11:02 PM
02/28/12 11:02 PM
ohio
Sherminator Offline OP
ohio
A BODY PICTURES AND WHAT TO DO
Re: FRAME CONECTORS [Re: Sherminator] #1187816
02/29/12 02:54 AM
02/29/12 02:54 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I don't have pics on this computer ( lap top & on the road ) , but I used 2X3" tubing.
Tied it to the torsion bar cross member with plates , went through the floor in the back seat and tied it into the front of the rear sub frame at the back.
So they are welded to the floor pan where they go through the floor behind the front seats and I opened the front of the sub frame and tied them in using the metal where I cut in as a tab on the bottom side and on three sides of each frame rail for the sides and top.
I could have drilled 3/4 " holes on the sides of the frame rails too and welded there , but I think I got it pretty secure.
Try the search and I bet you find a couple different ways to do this with pics.
I'll see what I have for images when I get home if you haven't found anything by then.
Re: FRAME CONECTORS [Re: tubtar] #1187817
03/05/12 11:56 PM
03/05/12 11:56 PM
ohio
ohio
anybody else
Re: FRAME CONECTORS [Re: Sherminator] #1187818
03/06/12 12:04 AM
03/06/12 12:04 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Look up Dizusters old posts. Frame connectors,mini tubs,and cage pics.
Doug
Re: FRAME CONECTORS [Re: dvw] #1187819
03/06/12 05:49 PM
03/06/12 05:49 PM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
I HAVE A used set of "bolt in" frame connectors that where on a 1971 duster for 1 month--my buddy took them off and parted the car out 10 years ago---
i would take $60.00 plus shipping for them---in the lower 48
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: FRAME CONECTORS [Re: Sherminator] #1187820
03/06/12 06:23 PM
03/06/12 06:23 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Old Geezer Racing
Re: FRAME CONECTORS [Re: SCATPACK 1] #1187821
03/06/12 10:03 PM
03/06/12 10:03 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Mine got pushed up to the floor and sectioned in the back to meet the rear frame stubs. No floor cutting. This is on a 72 demon with stock torque boxes. It made a night and day difference in the car's stiffness and several rattles and squeaks disappeared.
2x3" .125" wall
trans x-member area
rear frame stub area
Re: FRAME CONECTORS [Re: radar] #1187822
03/07/12 12:08 AM
03/07/12 12:08 AM
ohio
ohio
some good ideals
Re: FRAME CONECTORS [Re: Sherminator] #1187823
03/07/12 03:13 AM
03/07/12 03:13 AM
Oh
His and Her 69's Offline
Oh
I had my chassis guy bend and weld in some round tubes as my frame connectors on the woman's RR. They work Great, didn't have to cut holes in the floorpans, did weld them in sections to the floorpan, Good custom fit and made it stronger. Tucks up nice so no low clearances. Also easier to take out when car gets returned to stock (if it ever does). Sorry no photos though.
David
Re: FRAME CONECTORS [Re: Sherminator] #1187824
03/07/12 11:20 AM
03/07/12 11:20 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Re: FRAME CONECTORS [Re: Sixpak] #1187825
03/07/12 12:35 PM
03/07/12 12:35 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Pretty easy to do welded in ones here's my 69 Dart...
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: FRAME CONECTORS [Re: megajoltman] #1187826
03/07/12 02:40 PM
03/07/12 02:40 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I will try to find some pics, but I use 1.5x2 box (what I had laying around) and built 12ga "caps" to fit the front cross member and the rear rails, and welded to floorpan where I could (rear passenger floor board area)
also added another cross brace welded to the floor where the seat bolts are, and added an integral driveshaft loop.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: FRAME CONECTORS [Re: OUTLAWD] #1187827
03/09/12 11:10 PM
03/09/12 11:10 PM
ohio
ohio
alot of good ideals
