Doing away with trim rivets #1187026
02/27/12 04:15 AM
02/27/12 04:15 AM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Hey All, I am wanting to remove trim rivets from the body sides. You know the ones that secure the plastic trim clips. Anyway Other than drilling and filling every hole can these be cut off and smoothed with a flapdisk on a grinder? Just hoping I can get away with not having to weld and grind then fill and finish every hole. How have you guys gone about this? Thanks
Re: Doing away with trim rivets [Re: EV2RUNNER] #1187027
02/27/12 07:20 AM
02/27/12 07:20 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
As soon as you start to grind the heads, they fall in. Not a real big deal to put a piece of copper behind the hole and weld. finish off with flapper wheel and add filler as needed.
Re: Doing away with trim rivets [Re: None2Slow] #1187028
02/27/12 09:30 AM
02/27/12 09:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
grab them with a pair of vise grips and twist them off. TWIST do not pry or pull. TWIST them off..
I am truckless..
