Cutting lights #1186507
02/26/12 04:59 PM
02/26/12 04:59 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Been having a terrible time being consistent at the line. Leave on the yellow, and I red light. Leave on the green and it's way to slow.
I try to pause a bit after the yellow, and my reactions are all over the place. Anything from a .009 to a .2!
I run a small 24" tire due to my fenderwell headers and I've heard that could have something to do with it.
Car runs in the 10.30s and 60fts at 1.44. Leave off idle on the footbrake.
Any advice would be greatly appreciated.
Re: Cutting lights [Re: PolyDart] #1186508
02/26/12 05:08 PM
02/26/12 05:08 PM
Mesa, AZ
cagebob1 Online content
cagebob1  Online Content
Mesa, AZ
Your reaction time should be just that...a reaction to something on the tree. Reactions tend to be consistent, while thinking isn't. Find a spot on the tree where your lights are consistent, then adjust the car till the time is what you want. On all of my race cars changing stage rpms was the easy way to do it.
Re: Cutting lights [Re: cagebob1] #1186509
02/26/12 05:13 PM
02/26/12 05:13 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Good advice, to change the car, not you. Find the place on the tree, where you are golden, then change the car to suit. Try the other way around, and you'll soon have a legion of vultures following you to staging. You might find a delay class WAY cheaper in the long run, HOWEVER, the competition will probably much tougher, too. Good luck.
Re: Cutting lights [Re: Leigh] #1186510
02/26/12 05:20 PM
02/26/12 05:20 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Quit acting like me.
Re: Cutting lights [Re: bonefish] #1186511
02/26/12 06:37 PM
02/26/12 06:37 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
YES find your spot on the tree. and change the car reaction time..Can't say this to many times ! and from day to day you will change. need to learn to change the car for that day ! all kinds of ways to change the car.
Re: Cutting lights [Re: VernMotor] #1186512
02/26/12 07:36 PM
02/26/12 07:36 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Ok, let's say I want to leave on the last yellow. Other than a delay box, how would I slow down the car's reaction?
I did read where one of you said staging RPMS, but leaving off idle should give the slowest reaction since the engine has to come up on power, the suspension has to load, etc... I may be mistaken, but I would think I am already setting the car on the slow end of reaction.
Re: Cutting lights [Re: VernMotor] #1186513
02/26/12 07:40 PM
02/26/12 07:40 PM
PA
moparacer Offline
moparacer  Offline
PA
Well lets throw the leaving on the green out the window first. That will always bee too slow no matter what.
If you have 60 fts in the mid 1.40's you should be able to leave at the flash of the 3rd amber and not go red leaving at a dead idle.
That's another thing.....I have never been able to get a car to react consistently leaving at an idle foot braking.
You need some RPM to tighten the drive line and suspension up before you leave.
Try 2000 RPM and see how it works. If you RT is slow go up in RPM and vice versa if its too quick.
What you have to be careful of is not to anticipate the 3rd coming on. You need to leave when it comes on.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Cutting lights [Re: moparacer] #1186514
02/26/12 07:44 PM
02/26/12 07:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
The short front tire isn't ideal, but you should be able to make it work. The biggest issue is you. Go buy a practice tree and use it, you will improve.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Cutting lights [Re: PolyDart] #1186515
02/26/12 07:46 PM
02/26/12 07:46 PM
PA
moparacer Offline
moparacer  Offline
PA
If you are going red leaving the line at a dead idle you are anticipating the 3rd light coming on.
Re: Cutting lights [Re: moparacer] #1186516
02/26/12 07:48 PM
02/26/12 07:48 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
You're probably right. When initially working with the car I was all about best ET, now I have to forget that and work on best reaction times so I can go some rounds. The car definitely ETs best off idle, but it makes sense that it would be more consistent to leave with the suspension loaded.
Re: Cutting lights [Re: PolyDart] #1186517
02/26/12 07:50 PM
02/26/12 07:50 PM
Owasso OK USA
Cappy572 Offline
Cappy572  Offline
Owasso OK USA
All good advice on changing the car. Dont forget car placement in the beams is equally important for consistant reaction times and consistant ET. Make sure you barely turn on the second stage bulb to indenty you are on the same mark every time. This can be a differance of 2 hundreds on the starting line and the finish line. Stage deeper in the second bulb you will go 2 hundreds quicker on the tree and run 2 slower down track.
1970 AMX 572 twin turbo predator, 1970 Duster 572 B1, 1976 Gremlin 572, 1933 Plymouth coupe 340, Drag N Drive Events.
Re: Cutting lights [Re: moparacer] #1186518
02/26/12 07:51 PM
02/26/12 07:51 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Not the case. Since leaving off the yellow was too slow, I would pause and try to hit it half way between yellow and green. Since there was nothing to consistently react to, I was all over the place.
Re: Cutting lights [Re: Cappy572] #1186519
02/26/12 08:00 PM
02/26/12 08:00 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i have the same issue. when i leave like my bike i -.00x the car. i went up to 26"tall tires from 25". that should put me in the ball park. but i have proparts headers and can get away with taller tires better.
i will find out this season.
Re: Cutting lights [Re: PolyDart] #1186520
02/26/12 08:02 PM
02/26/12 08:02 PM
PA
moparacer Offline
moparacer  Offline
PA
I think you are mixed up here a little.
If you were slow leaving off the yellow, waiting to leave between the yellow and green would make you even slower.....
I dont know...Anyways look at this video me me in my old car footbraking with a setup similar to yours.
http://youtu.be/BaAvUO4LRPs
I am leaving at 2000 RPM and leaving when the 3rd light comes ON.
This wasnt a killer RT I think around .030 or so but this is how I have done it, and won a lot of races over the last 23 years.
Re: Cutting lights [Re: PolyDart] #1186521
02/26/12 08:02 PM
02/26/12 08:02 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
yes I would try to leave off the last yellow with some RPMs first. see where that gets you. changes to the car tire pressure.. rear and front. T-bar adjustments. you may even need to send the converter in and have the stall speed change..there is more but depends on what suspension you have ? leafs-ladder bars-4-link .. and shocks play a big part in this.. Lets face it.. no matter how fast how cool you look..if you can not cut a light you will never go rounds..I do what ever it takes on a given day to make that happen. and yes make sure you stage light and same way every time.. this is very very importance.
Re: Cutting lights [Re: PolyDart] #1186522
02/26/12 08:02 PM
02/26/12 08:02 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
You can try adjusting your front tire pressure, too slow-increase pressure, too quick-let air out. But I do agree you have to be right first before you can get the car right. Try staging, adjusting launch rpm, make sure your carb is reactng properly run after run, proper pressure rea tires, shocks set correct. A lot more, this just starting point.
Re: Cutting lights [Re: PolyDart] #1186523
02/26/12 08:08 PM
02/26/12 08:08 PM
WA
JD Dart Offline
JD Dart  Offline
WA
If your distributor isn't locked out change the curve on it like all in at 4800 or what ever max curve you can get out of it. Also have the centrifugal advance timing set to the max. Like with the MSD you can have it setup for 28 degrees so if you wanted 36 total you would set base timing at 8 it will run bad and very sluggish when you tip into the throttle. At that setting you may have to leave on the second yellow.
Re: Cutting lights [Re: JD Dart] #1186524
02/26/12 08:12 PM
02/26/12 08:12 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Yeah, I wrote that wrong. Leaving when I see the yellow leads to a red light, which is why I paused and hit it between yellow and green. Sorry for the confusion.
Re: Cutting lights [Re: moparacer] #1186525
02/26/12 08:13 PM
02/26/12 08:13 PM
Az
Crizila Offline
Crizila  Offline
Az
Yep - almost for sure on that. This was something I had a problem with ( especially running slower cars ). You have to discipline yourself to make sure you see the light come on before you mash on it. As said, a practice tree will help, but the best thing is just time in the seat and sticking to a routine. My routine starts once I am positioned in the water box. If I have to shut down after that due to track conditions, I always back all the way out of the box and start over again - no matter what my apponent does. I also always look at his dial to make sure I know who is going to be leaving first.
Fastest 300
Re: Cutting lights [Re: Crizila] #1186526
02/26/12 08:19 PM
02/26/12 08:19 PM
PA
moparacer Offline
moparacer  Offline
PA
Yep a lot of guys dont realize that the fact that you know the tree is dropping can make you 3 or more hundredths quicker. You are mentally anticipating it.
Just hold your hand up and block the first two once. Then you will see just how much slower it makes you.
Also, get someone to video you at the track like I posted up above.
You will be able to tell exactly where you are leaving at and can adjust accordingly.
