rear end bearing questions #1185795
02/25/12 01:13 PM
02/25/12 01:13 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I have pulled the rear axel from my 65 barracuda. When I was going to re-line the rear brakes everything was covered with dirt and grime which I assume is from a leaking rear axel seal. The bearing seems good. My question is do I need to replace the bearing and I believe their are 2 seals? I have everything apart now and am at a stand still. Also do I need to have someone press the bearing on if I have to replace it.
Thanks,
Tommy
Re: rear end bearing questions [Re: Tadams] #1185796
02/25/12 01:19 PM
02/25/12 01:19 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Thanks,
Tommy
If you have rear end lube in the brake area replace the inner seal The outer seal is more of a dust seal to keep dirt and debrie out of the bearing area. It is usually only replaced when the bearing is replaced. Clean and repack the bearing with a good wheel bearing grease and reinstall the axle as per http://www.moparts.org/Tech/Archive/axle/12.html
Re: rear end bearing questions [Re: MoparforLife] #1185797
02/25/12 01:20 PM
02/25/12 01:20 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Hi, thanks for the info. I guess I will order some parts and go ahead and finish the front end while I wait.
