Re: A body 8 3/4" axle questions.
[Re: Kern Dog]
#1185698
02/25/12 05:35 AM
02/25/12 05:35 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the stock A body 8 3/4 used small bolt pattern axles and IIRC 1 3/4" drums and shoes. If your going to use aftermarket big bolt axles you can use any 10" or 11" brakes and backing plates off of any 8 1/4, 8 3/8, 8 3/4 or 9 1/4" rearend
I am truckless..
[Re: Kern Dog]
#1185699
02/25/12 11:32 AM
02/25/12 11:32 AM
RapidRobert
If you were going w SBP I see pairs of axles for $50-100 and they would require the specific backing plates/SBP drums matched to those axles and as said the 1&3/4 wide shoes
[Re: DirectSubjection]
#1185703
02/25/12 01:12 PM
02/25/12 01:12 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
And they will set your wheels out a little bit more than the stock a-body abp axles would.
When going from A body SBP 8.75 and SBP 14x5.5 Ralleys to A body LBP 8.75 w/aftermarket axles and LBP 14x5.5 Ralleys, tire location in the wheelwell will be the same. OEM SBP wheels have less backspacing to make up for the narrower flange to flange width.
Backing plates from a LBP 7.25 rear will also work.
